cleaner fuel
Do fuels with no castor just synth. oil burn cleaner?
RE: cleaner fuel
No, not really, but the castor oil is what turns brown on your engine from the heat. Not sure I'd recommend fuel without castor, but I know people do use it.
Dennis- |
RE: cleaner fuel
Fuels without castor NORMALLY do not leave the brown, baked on residue seen on the engine. IMHO, the down side to an ALL synthetic oil fuel is the lack of protection for the engine in case of a lean run. The castor leaves a residue inside the engine that helps protect the engine from rust and lean runs.
RE: cleaner fuel
The castor leaves a residue inside the engine that helps protect the engine from rust and lean runs. |
RE: cleaner fuel
It is quite easy to keep an exhaust deflector on. Use your dremel (or a small triangle file) and cut 2 SHALLOW grooves all the way around the exhaust tip of the muffler. When you put the deflector on it should not come off after that. I have several planes with exhaust deflectors on them. Since I put the grooves in the exhaust tips, I haven't a single one come off.
RE: cleaner fuel
I use deflectors and after some trial and error I found the best and most assuring way to keep them on is to attach them then drill a 1/16th inch hole right through the deflector and the muffler tip. Then run a small piece of wire through the hole and loop it . Works great and havent lost one yet....especially at almost $3 apiece.
RE: cleaner fuel
It just seems odd that we use castor oil. We dont really use it in motor oil anymore( there are exceptions) because it does not perform as well as synth or natural petro based oil.
RE: cleaner fuel
Burn cleaner, NO
Burn without a residue, No Has less varnish and is less sticky, Yes ORIGINAL: dolsen Do fuels with no castor just synth. oil burn cleaner? |
| All times are GMT -8. The time now is 07:05 AM. |
