firebird xl cg
[img]i/expressions/face-icon-small-confused.gif[/img]
after the big crash new wing etc after hand launch just dives for the ground i think the battery has moved forward given nose down where is the point of balance on the firebird and how do i check this or is there anything i might have missed |
firebird xl cg
I fly an Aerobird, but it is a very similar plane to the Firebird XL so some of the tips and fixes I give here may apply to your problem. I have been flying my bird for three months and 50+ flights and just lovethe
plane. I have pounded the plane into the ground, destroyed three wings, and a tail. I had to build a new motor mount because I destroyed that too. All this, and the plane flies great, but it has taken a real beating. That is what makes it such a great three channel trainer. Along the way I have had to solve many problems brecause I was so reckless with it while I was learning to fly it. So, I pass on what I have learned. First - RTFM If you lost your manual, you can download it here: http://www.hobbyzonesports.com/Produ...uctID=HBZ6000# Respect Wind This plane can fly in winds up to about 12 MPH and I have flown in 15 MPH winds. However wait till you have mastered it. Most of my crashes came from flying in too much wind before I was ready. Always launch into the wind and land into the wind. And, with the wind blowing toward you, the wind will not carry your plane away, it will tend to bring it to you. Once you master flying the plane, the wind can be your friend. Respect the wind, don't fear it. Motor Mount This is the first thing you should do. Before you take a hard nose hit, reinforce the motor mount. I will not elaborate here, visit this thread to find the information. It contains advice from other pilots and what I finally did to reinforce the mount. You should do this before you need it. http://www.rcgroups.com/forums/showt...187#post922187 Plane Does Not Fly Straight Assuming you have not displaced the motor (see above), and you are having problems with the plane turning to one side, check the following: a) is the wing crooked or too damaged - try a new wing. b) Check the trim adjustments. They may have been moved from center. Set them to center and make all adjustments assuming you will fly with the trim set in the center. c) Check the tail. The foam is attached to the center plastic brace by small pieces that punch through the foam. This can loosen up and the tail fin can move slightly away from the plastic brace. On the ground you might not notice it, but in the air the pressure can move this around causing the plane to turn to one side or the other. Tape or glue the tail fins to the center plastic brace. Also, look for creases in the foam. If there is a weak spot, it will cause the tail to flex causing the plane to turn. mine was creased at the meeting point where the plastic support meets the tail, so did not see it. Looked fine on the ground, but it was flexing in the air causing a hard right turn leading to crashes. I replaced the tail. d) Make sure the moveable surfaces are even with the fixed surfaces on the tail when the stick is centered and the trim levers are centered. You MUST check this with the transmitter on and the battery attached. If they are not even, adjust them with the screws on the control horns. If they are not even when the stick is centered, then the plane will not fly right, ever. The procedure is in the manual. RTFM Note, there is a tiny phillips head screw on the back of the control horn on the tail. Tighten it or the spool could unwind while the plane is in the air, causing a crash. (Guess how I know this!) e) If none of the above are not a problem, then check to see that the boom is solidly attached at the body of the plane. If this comes loose, it can move around while the plane is flying causing all kinds of problems. It can also twist so that the tail is no longer aligned. Since the body is polypropylene, not much in the way of glue sticks to it. This links shows you how one person secured the boom on their plane using screws. http://rclibrary.com/viewtopic.php?p=34#34 Be sure to put the screws FORWARD of where the control lines enter the boom. You have to look into the plane to see this point. I have also heard of people drilling holes from the side and putting nylon ties through the holes to secure the boom. Just make sure you are forward of control lines. The Porpoise When you apply power the plane starts to climb then noses up, then the nose drops and it does it all over again. The problem is that the tail needs to be trimmed. There are two screws on the tail. The procedure is in your instruction book. RTFM Center of Gravity If you are using a 7 cell battery, you will get a faster plane and better climb. However you will also shift the center of gravity forward slightly. Not enough that the plane won't fly, but enough that it will seem to be nose heavy. If you are an aggressive, full throttle flyer, you probably won't notice. If you are more of a half throttle cruiser, like me, you will find the plane needs up trim all the time. Here is how you fix it. The foam that sits between the battery and ahead of the electronics puts the 6 cell exactly where it needs to be to balance the plane, but the 7 cell is heavier. Remove the side pins and pull the foam out. Now, cut it from top to bottom about half way in, just in front of where the pins that hold it in-place enter the foam from the side. Now put the remaining piece back in the plane. When you fly the 6 cell, put the moveable piece behind the battery in its normal place. If you are flying the 7 cell, put the moveable piece forward of the battery. This will shift it back 1/2 inch and put the CG right where it should be. The plane will fly better at all speeds and will launch much better as well. Longer flights Bback off on the power. Both the 6 and 7 cell battery will last five to seven minutes at full power. However, if you back off to half power, your flights can last 10-12 minutes depending on the wind. If you back off to 1/4 throttle or glide, you can stretch beyond 15 minutes. Also, when you charge your batteries, charging at a lower rate gets fuller charges. If you are not at the field, but are charging up after the day is over, or the night before, charge at .6 to .8 amps instead of the full 1.2 amps. It will take longer, but will heat the cells less and will more fully charge the battery. Neck Strap for the Control unit. If you look at the high priced Futaba, Hitec and other radios, they have a place where you can clip a cord so that the radio can hang from it leaving you two hands to make adjustments on the plane. I have messed up the trim taps more than once and crashed on launch because I tucked the radio under my arm. Take a large paper clip and bend up the center piece in the middle to make a place where you can clip a neck strap to it. Now take some sand paper and sand a spot in the center of the radio to the left of the stick and the right of the throttle slide. Mine is about 1/3 from the bottom of the radio. Sand the area, then epoxy the paperclip to the radio. Use plenty so you can really embed the clip in the epoxy. Now, when you are getting ready to fly, you can release the radio without putting it down. Reinforce the Wing Got to staples and get some glass reinforced tape. The 3M type that has a cross pattern is best. I think it is called extreme strength tape. Put a piece on either side of trailing edge where the prop wants to bite the wing if a landing is a little rough. Make sure you have a spare prop. Since the prop is less likely to cut the wing, if it hits the wing, it might pop the prop off, or break it. However normally this does not happen. I also reinforce the front of the wing with the same tape where the rubber bands come across the wing. This will help reduce denting. Learn to Dead Stick Land If you run the battery too long, the speed control will cut the power to the motor while preserving power for the control surfaces. If you learn to land with the power off all the time, then if you get caught in the air with no motor, you will have no problem landing. Dead stick is my standard way of landing. If I am 250 feet up and want to land, I just set the plane into a landing direction then cut the power and glide it down. Also, since I fly on a grass field, I never use the landing gear. I just slide it into the grass. Parts These planes have a great distribution system. Parts are very readily found in most hobby stores. However if you can't get what you need, look here: http://www.hobbyzonesports.com/Support/ HobbyZoneSports Frequently Asked Questions - Couldn't hurt to look! http://www.hobbyzonesports.com/Support/FAQ.aspx Summary So, that is the sum total of what I know about getting a great plane through the phase where we pound it into the ground trying to learn to fly. Don't give up! Avoid the wind, take your time and you will get it! Oh, and RTFM ..... read the friendly manual!!!! :-) |
firebird xl cg
You might have missed something I missed after the first crash. The tail-boom came loose from the little clamping
system on the bottom of the fuselage. I have since secured it so it can't pop out of place.[img]i/expressions/face-icon-small-smile.gif[/img] |
firebird xl cg
The Firebird XL balances between 1/3 and 1/4 back from the lealding edge of the wing. Be sure you put the wing in the proper way so the straight edge is the trailing edge.:cool
firebird xl cg
Hello All,
I am a newbe to this hobby! Recently got the Firebird outlaw 2 Ch airplane........On the first time I flew her she flew very well but I couldn't control the turns/steering so it crashed into the compound wall ,at least on 3- 4 attempts....Lucky nothing broke!!.....But when I took her out again for a fly,I found that after flying a distance ,I had absolutely no control and down she crash lands!!...This time I break the booms housing the motors,and had to stick them up!!....On rechecking I found range problems.....The motor would sputter(start/stop) and hence it would crash when launched after going some distance!......could this problem be because of the cell power become weak or is it due to the range become less!!....Please Help |
firebird xl cg
Ok I found out the problem!! It was range problem!.........not the cell power reduced
But the coil from the wire antenna to the further ckt had snapped due to the motor booms breaking onto it...Added a jumper and joined the coil to the receiver PCB ....Now its fine !! Only have yet to test fly again!!wish me luck to fly well!!!! |
firebird xl cg
The boom breaking loose on the Firebird will definately cause it to nose down.
The CG on these planes is pretty much fix. You can't really affect it much unless you go to the 7 cell battery. Read my post above in the section about won't fly straight. |
firebird xl cg
Yes! It does tend to fly left and at first even went nose down!...But adjusting the trim tabs did help in getting the required lift !though she turns left at times....The fire bird Outlaw has a cell pack of 6Volts ie. 5 Cells of 1.2V each.
A 7 cell pack will be out of the question as the fuselage won't have that much space for the extra cell....but with 7 cell at cruising speed(less throttle) won't it go nose down? I would like to know how often should the cell pack be charged....If it is kept idle for long periods of time. Does charging discharging the cell pack often reduce the life of the cell pack? |
firebird xl cg
Jonboy,
Sorry for the confusion on 7 cells. I was refering to the Firebird XL at the begining of this thread. I am not familiar with your plane. I have an Aerobird. |
| All times are GMT -8. The time now is 07:00 AM. |
