RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   what about prop position? (https://www.rcuniverse.com/forum/beginners-85/1881819-what-about-prop-position.html)
kokamo 06-07-2004 06:22 PM
I know there is a way to position the prop on the engine(two stroke) to where I can start it by hand. I'm just not quite sure of where. Is it strait up at about the 12-o-clock position just before the compression stroke? or when the piston is a tdc? Just a quick question. What is your opinion???
BTW...this is an evolution engine on an alpha 40 trainer with a two blade prop instead of the original three blade.
Thanks to all in advance!!!
Joe
ifixairplanes 06-07-2004 06:33 PM
RE: what about prop position?
best thing to do is bump the engine against the compression stroke in direction of rotation, dont follow through, just bump it. then set the blades at the 9 and 3 o'clock postions. I find it easy to start this way when i need a quick restart (grass nose over or something) and also if you have your engine die in flight it will stop like this and you reduce the chance of the prop sticking in and braking on landing.
sean
jettstarblue 06-08-2004 07:27 AM
Good advice, Sean. I second that!
MinnFlyer 06-08-2004 08:41 AM
There is no right or wrong prop position. Wherever it's most comfortable for you to flip it is the best place. Most people I know prefer a 1 - 2 o'clock position.
Love2FlyMN 06-08-2004 09:58 AM
I prefer it at 1-2 oclock
Mike in DC 06-08-2004 11:52 AM
I was always taught that you bolt the prop on at 3/9 o'clock, so that if you dead stick, the wind will keep the prop horizontal and safe for a bad landing. By coincidence, that seems like a pretty good place for starting as well.
Josey Wales 06-08-2004 01:01 PM
ORIGINAL: Mike in DC
what he said!!:)
phread59 06-08-2004 06:26 PM
Yup 3&9 here as well. That is where I put all my props (when I remember).
Mark Shuman
