RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Reverse Servo (https://www.rcuniverse.com/forum/beginners-85/19162-reverse-servo.html)
egrave 07-07-2003 06:43 PM
Reverse Servo
When using two servos with a Y harness with out turning one 180 degree how do you get one servo to work oppsite from the other. In other words the instruction say to have the arms facing the wing tips. Is there such a thing as a reverse servo.
daveopam 07-07-2003 07:23 PM
Reverse Servo
There are several companies that make a miracle Y-harness. I get mine from Expert. The miracle Y reverses one of the servos for you. It also has a centering pot. This should be a last resort. If you can fix it mechanically or mix it in your radio, I would do that first. later daveo
ballgunner 07-08-2003 12:51 PM
Reverse Servo
Your aileron servos will work just fine as they come out of the box. Just pick up the action for the aileron push rod from the opposite side of each servo. They will still turn in the same direction but the action will be reversed when you use the opposite side of the arm.
