Somethin Extra
how would the sig something extra be for a second plane? i fly a aerobatic trainer with 1 inch dihedral, and i have the throws set pretty hight for a trainer...it will do loops, immelmens, split ess's, and rolls. i just didnt know if it would be a good second plane.....thanks for the help
RE: Somethin Extra
If your skills are that good, you can probably handle an SE
RE: Somethin Extra
Sounds like the SE would be a fine choice. Start with the rates down low, then increase them as you become more comfortable.
RE: Somethin Extra
Somthin' Extra makes a great 2nd plane. It can be set up from mild to wild!! It makes bad pilots look good and good pilots look great. :D
Just don't EVER give your plane a name! Cause' 2nd planes tend to splater:( |
| All times are GMT -8. The time now is 02:34 AM. |
