cleaning engine
I was wondering what is the best way to clean the "varnishing?" on the outside of an engine,I have an Alpha 40 with the evolution trainer engine on it,and it is starting to look a little ragged.Any help would be appreciated.[&:]
RE: cleaning engine
re-post this in the glow engine forum. they have a definate answere for you.
RE: cleaning engine
Get a $7 crock pot from WallyWorld, fill it with 50-50 car antifreeze, partially or completely disassemble the motor, and soak it 24 hours with heat on. Brush any remaining crud off, rinse well, dry in an oven (if you can get away with that at your house) or with a heat gun. Oil well with air tool oil, reassemble and test run. The antifreeze really cleans 'em up. Careful where you store the antifreeze. Keep a long way from pets and kids.
RE: cleaning engine
Couple of things to add to what kdheath said:
1. Do this OUTSIDE. The fumes WILL get to you. 2. DO NOT USE THE CROCKPOT FOR FOOD. The antifreeze gets into the pores of the liner and will contaminate (read this as poison you) anything cooked in it afterwards. 3. Dispose of the antifreeze in a safe manor. Animals (and kids) like the sweet taste - it will kill them. |
RE: cleaning engine
What they said. Also, use the "low" setting on the crock pot. (Too much heat, or too much time in the 'pot' can cause the aluminum to discolor.)
Dennis- |
RE: cleaning engine
Campy... I love your "warnings" They are needed these days!!
Just makes me think... What ever happened to good ole.. C. S. |
| All times are GMT -8. The time now is 09:45 PM. |
