3 Channel control
I am looking at getting a 3 channel electric. I have already had a Firebird Commander, but want something with seperate servos and not all built into a control board. I have seen 3 channel electrics that control throttle, rudder and elevator, while others control throttle ailerons and elevator. Which of these is better? I will probably get a 4 channel radio so I can upgrade eventually, but the 3 channel is what I want to start with. Thanks.
RE: 3 Channel control
i started with a T-Hawk from Toytronics at readytoflyfun.com ....... best little 3 ch. electric i think you can get, its durable, fully compatible with all standard servos and etc, has horizontal stabilizer control, vertical stabilizer control and variable throttle .... i used this plane as a beginner so that i was able to move up to a 4 ch. glow plane, now i fly an xtra easy 2 and i can honestly say that that little plane prepared for this much larger and complex plane.......... i've flown that T-Hawk into the groud, fences, etc...... and it has never let me done... it comes ready to fly, two NiMH batteries, two wings, two tail sets and 3 props...... all you need to get you on your way .... parts are very cheap, $10 for new wing, $5 for new tail , etc....... i highly recommend checking this plane out as a first 3 ch. electric ....
I also see they have a new plane called the predator. Any opinions on which is a better plane?
The T-Hawk is better for a beginner, the Predator is more of a speed plane, not as forgiving as the t-hawk ....
Thanks. I think I will give it a try.
| All times are GMT -8. The time now is 12:02 PM. |
