RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   The engine that keeps going (https://www.rcuniverse.com/forum/beginners-85/2073652-engine-keeps-going.html)
bobbykokinos 08-10-2004 09:51 PM
What could cause an engine not to shut off?? When I close the throttle, the carb is closed just by looking at it, but the engine still wants to run.. Only way I can get it to shut off is by putting my finger on the carb.
Any ideas?
Righty 08-10-2004 09:55 PM
RE: The engine that keeps going
haha
It's alive![sm=bananahead.gif]
raideron 08-10-2004 09:56 PM
You may be sucking air around the carb.. I believe you can adjust the
amount the barrel of the carb closes that may help.. As long as the carb
is on tight and not leaking/sucking air elsewhere...
jcflysrc 08-10-2004 10:00 PM
AIR LEAK!
Jim
bobbykokinos 08-10-2004 10:02 PM
ORIGINAL: Aeronaut
AIR LEAK!
Jim
The only place I think I MAY be getting a leak is in the exhaust.. I had to drill a whole in the muffler for the exhaust vent because it didnt have one.. Even though it comes from the tank straight to the muffler, could this be where its at?
campbec 08-10-2004 10:19 PM
Hi,
As the others have said it has to be an air leak on the inlet side. Check the needle valve assembly by placing a piece of fuel tubing around the shaft of the needle vave, (you have to remove the needle then slide on the fuel tubing over the spray bar then reinsert the needle and reset). It could also be sucking air around the carby body where it fits into the housing with a possibly damaged O ring or through the screws that locate the carby. It could even be a missing screw from the back plate or an ill fitting back plate. Try changing one thing at a time and use the process of elimination.
Good Luck,
Colin
CafeenMan 08-10-2004 10:22 PM
Sounds like an air leak to me too. You said you can see the carb is all the way closed so this probably isn't the problem but check that the throttle stop screw doesn't stop the barrel from closing far enough to shut off the engine.
That's the little screw behind the carb that's normally on the right side as looking at the engine from the cockpit. It also holds the carburetor barrel in so it doesn't fall out. :)
a65l 08-10-2004 11:42 PM
Second the throttle stop screw, sounds like it's an older engine, and on a well broken in engine the throttle only has to be open a very slight amount to idle.
Andy
Fastsky 08-11-2004 08:17 AM
What engine is it?? There are some brands that known to have this problem such as the GMS and Tower Hobbies engines. I have a Tiger Shark 75 that does that. If thats the case and its new you can ask for a replacement. Sometimes a replacement will be fine and sometimes it will have the same problem. All I do to shut down the 75 is go to high throttle and then back to idle quickly. The sudden extra fuel combined with not enough air to burn the fuel causes the engine to flood and kills the engine. [8D]
bobbykokinos 08-11-2004 01:08 PM
Thunder Tiger .46
Ed_Moorman 08-11-2004 01:34 PM
I've never heard of a TT .46 not shutting down. Has anyone else?
I own TT, both Pro & GP, OS AX, GMS, Evo, Magnum 2 & 4-stroke and Tower. The only 2 that won't shut down immediately are the Tower .46-it takes 30 seconds or so and a new Magnum .70 4-stroke-takes a minute to stop. The Tower is on a float plane-how's that for matching an engine to a purpose. The Mag .70 is still in a Big Stick being broken-in.
You might need to let one of your local experts look at the engine and help you tune it. TT .46s are great engines and as you can tell by the number of questions on them here on RCU, there are only rare problems. You may just have one of the 1% that slipped through quality control.
Campy 08-11-2004 01:43 PM
You have an air leak.
The USUAL suspects are:
O-Ring seal between the carb and the engine.
Backplate.
Both of these can easily be remedied. Remove the carb and clean the area underneath where the O-Ring is. Then apply a LITTLE silicon sealer to coat the O-Ring. Press the carb FIRMLY down and WHILE HOLDING THE CARB DOWN tighten the screw(s).
For the backplate it is basically the same thing - remove, clean, a LITTLE silicon and rebolt.
mattbeme 08-11-2004 06:33 PM
I'm with Campy, it sounds like air leak around the carb body where it slides into the engine. Evolution engines seem to be famous for this. This little O ring at the bottom isn't a very good design. It's too thin. use the sealant trick. I always use automotive silicone sealants-- ULTRA GREY, BLUE OR COPPER. They work great. Just put a small amount around the carb and on the screw which holds the carb in place in the engine. Do the back plate too. They ususally use cheap gaskets there too.
bobbykokinos 08-11-2004 07:31 PM
Now, for a curious question.
If there is a leak between the carb and the body, why does it shut off when I put my finger on the carb?? If the leak was there, wouldnt it keep running because the entry point of the leak is PAST where I'm blocking the air?
FlyerBry 08-11-2004 07:46 PM
ORIGINAL: Ed_Moorman
I have two TT .46 pros and they both take a little time to shut down. They do eventually quit but it definitely isn't as immediate as my other engines which are all four-strokes. If I really want the engine stopped immdiately I just reach down and grab the spinner. Not the safest tactic around but it works. Most of the time I just let it quit on its own because it is already barely running at that point. I guess I'm too happy with the performance I get out of these engines to worry too much about it.
Mike Ledbetter 08-12-2004 12:36 AM
Because when you cover the carb with your finger, you press down on it, sealing the leak.
DUDE, Where's My O-Ring?
