fuel question
Benn running omega 15% in engine since I had it. My questins is would any other fuel 15% be about the same or should I try to keep on using same I was using before. Reason is hobby shop around me closed down and the one thats closest has another brand than omega
RE: fuel question
The Morgan City shop carries Omega.
What brand is being sold nearest you? Jerry |
RE: fuel question
You can use any fuel that is sold at LHS. Dennis
RE: fuel question
You might have to move your needle valve 2 clicks in either direction, but any brand will do......it's pretty much personal preference, or, what's available at the time. ;)
RE: fuel question
Hi Guys,
Might I suggest you save lots of $s and make your own? If you mix 20% Coolpower Blue Oil, 10% Nitro and 70% Methanol both two and four strokes run perfectly and this mix meets the warranty specs of all manufacturers (at least in Australia it does). By buying methanol in bulk along with the oil and nitro methane you save heaps and never have to worry about consistency. If you have an engine that is inverted up the nitro content to 15% and it won't stall when throttled back on long finals. Cheers, Colin |
RE: fuel question
Might I suggest you save lots of $s and make your own? If you mix 20% Coolpower Blue Oil, 10% Nitro and 70% Methanol both two and four strokes run perfectly and this mix meets the warranty specs of all manufacturers (at least in Australia it does). By buying methanol in bulk along with the oil and nitro methane you save heaps and never have to worry about consistency. If you have an engine that is inverted up the nitro content to 15% and it won't stall when throttled back on long finals. |
RE: fuel question
Speaking of fuel costs..... I just spent $23.00 on a gallon of Byron 15%!!! Don't think I'll be going to that hobby shop anymore. I can drive 10 minutes farther and get 15% for $13.00.
RE: fuel question
I looked into home brewing my own fuel and the savings were not nearly what I thought they would be. You have to buy huge quantities of the ingredients to see an appreciable savings. I know you can make the FAI fuel cheaper but the saitos love that nitro.
There is an interesting thread on this. Check out post 152. This guy can make a gallon of 15% for 10 dollars and some change. I can get a case of 15% for 48.00. Not worth it for me unless I buy a 55.00 gal. drum of methanol. http://www.rcuniverse.com/forum/m_19...brewing/tm.htm |
RE: fuel question
the brand thats sold at my hobby shop is cool power 15 I have been using omega 15
RE: fuel question
ORIGINAL: bodypilot Speaking of fuel costs..... I just spent $23.00 on a gallon of Byron 15%!!! Don't think I'll be going to that hobby shop anymore. I can drive 10 minutes farther and get 15% for $13.00. The other fuel should be fine |
| All times are GMT -8. The time now is 02:49 PM. |
