RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   MOD Questons for an Alpha 40 (https://www.rcuniverse.com/forum/beginners-85/2171561-mod-questons-alpha-40-a.html)
Cole_lol 09-13-2004 07:56 PM
Im just looking for some mods for the alpha 40. I know about the tail drager one but I was wondering if there may be any others.
Cole
LearjetMech 09-13-2004 09:05 PM
RE: MOD Questons for an Alpha 40
Rip off that flywheel and go to an APC 11X5. I glued my tail down. And what tail dragger mod? Fill me in!
tukkus 09-14-2004 06:03 PM
i have a Alfa trainer and the first thing i have done so far is put in a .68 engine(bought it brand new for $50), if you plan on keeping the same engine use a two bladed prop, and the things i have planned are;
install nylon bolts instead of using rubber bands
converting to tail dragger
taking out the dihedral in wing
change the covering to give it a better look
and if that all works out maybe i'll use a 6volt reciever battery for better servo response and turn it into a low wing plane and maybe round off some of the corners on the fuselage to get rid of that box look it has now.
bingo field 09-14-2004 07:29 PM
http://www.rcuniverse.com/forum/Alph...2118831/tm.htm
This has photo's and explainations on conversion to a taildragger, and if you ask Britbrat, he can show how the fuselage can be changed with rounded corners.
Hope this helps.
This is Britbrats' fuse mod...
bingo field 09-14-2004 08:18 PM
1 Attachment(s)
One more try...
tukkus 09-14-2004 08:37 PM
bingo can you get a closer picture of the fuselage so i can see if it's even worth bothering with.
bingo field 09-14-2004 08:41 PM
I got the picture from Britbrat, he may have something closer....
