Hinges?
Are Du-Bro hinges installed the same as CA hinges? Can you put the Du-Bros in a slot that was previously occupied by CA hinges?
Probably stupid questions, but thought I'd ask anyway. Having to do a little repair work. Thanks |
RE: Hinges?
1 no
2 yes Install the hinge, make sure it has a good fit, then remove it, smear some epoxy on the hinge and in the hole, and replace the hinge (A little vaseline on the pin will help it stay free of epoxy) Wipe off excess epoxy with alcohol |
| All times are GMT -8. The time now is 06:10 AM. |
