RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   3 blade or 2 on LT-40... (https://www.rcuniverse.com/forum/beginners-85/2228961-3-blade-2-lt-40-a.html)
exeter_acres 10-05-2004 04:32 PM
Just getting started with my Kadet LT-40.......
using an OS .46 AX
with various size APC props....
any reason why I can't use a 3 blade prop....?
and if I can, what size....
I just really like the looks of them..
is there a reason I "shouldn't" use a 3 blade????
Just curious
Thanks!!!
Exeter
Scar 10-05-2004 04:40 PM
RE: 3 blade or 2 on LT-40...
There are positive and negative things about using a 3 blade on your LT-40.
On the plus side, they do look nice, even unusual.
They're less efficient, in the small sizes we use, and that's good for a trainer. Keeps it a little slower, more time to react, while providing a good load for the engine, to keep the glow plug warm, less stalling.
On the negative side, they're expensive, and sometimes we break a prop on landing. And, the spinner costs a bit more.
Welcome aboard, and enjoy your plane!
Dave Olson
britbrat 10-05-2004 06:53 PM
For models, there are no positive things about a 3-b prop, except ground clearance & appearance. Your LT 40 has ample ground clearance, so use a 2-b prop --- 11-5, 11-6, or 12-4. The 3-b will give you poorer flight performance from every aspect.
