RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   4 channel RTF electrics? (https://www.rcuniverse.com/forum/beginners-85/2291105-4-channel-rtf-electrics.html)
chuckd 10-26-2004 08:04 PM
Hi, can anyone recommend a good 4 channel ( aerilon, rudder, elevator, throtel) electric RTF to buy, all I can find are three channels.
Chuck
Spaceclam 10-27-2004 12:02 AM
RE: 4 channel RTF electrics?
electric rtfs are usually small, trainer-park flyer type planes that do not require 4 channels. they use 3 because it is cheaper and it still works fine. I am assuming you are talking about park flyer size to 20 size? if that is the case, i would just get the plane you want in arf form and put in the gear you want. arfs of that size have very little building required. mostly just gluing on the stabs and installing the gear, and that is it. if you insist on nothing but a good 4 channel rtf electric, you will find that you are extremely limited in choices whereas there are hundreds (literally) of different models in that size to choose from to fir your taste, and you will also be able to put in the gear you want. rtf electric stuff is usually very underpowered. you may want something with a little more power, or an esc that can handle lipos because most rtf ones will not come with an esc with a cut-off or maybe you want brushless. either way, your best option is to get either a foamy, (practically no building at all) or get an arf (mostly just gluing) and install the stuff you want.
however you can check out www.parkflyers.com and see what they have there.
Flypaper 2 10-27-2004 08:51 AM
One good four channel plane is the GWS Tigermoth 400.
Spaceclam 10-27-2004 06:03 PM
i would haveto agree there.
aeajr 10-30-2004 09:44 PM
This is a 4Ch RTF Electric:
Begin-Air/Wing Dragon Sportster - RTF -
Have not seen one fly in person but it looks interesting
Both sites have video - Video at second links is MUCH Better!
http://www.parkflyers.com/html/begin-air.html
Photos and video (slow download)
http://art-tech.cn/english/ArticleShow.asp?ArticleID=88
