TT MK2 converting to tail dragger
Hey guys/gals,
Today was a little bit gusty at the field and when The engine died about 10 feet off the ground my plane didnt really have a chance. luckily all that was broken was the nose gear. So I got some instructions from a local on how to convert this into a tail dragger. But now im having some trouble finding the actual landing gear. Iv got the tail wheel and axle. but I need the upper gear. It needs to be 3" wide at base. so please help me out |
RE: TT MK2 converting to tail dragger
http://www2.towerhobbies.com/cgi-bin...&I=LXNM65&P=RF
That should give you a start, there are others, similar in nature to that one available. Here is a conversion similar to yours, with some pictures and some explainations that might help if you come up with some questions. http://www.rcuniverse.com/forum/Alph...2118831/tm.htm |
| All times are GMT -8. The time now is 11:06 PM. |
