Tips and thoughts:-)
Hi all... Hope your new year is starting off great!! Well, as for me
mine started with a little glitch:-( At the field today my ailirons had a few glitches (all other controls were fine) (Even with my 4* pulling into a hover at about 10-15' right after lift-off:-).. Sorry I had to throw that in.. That was a first for me:)))))))))) It would every now and then drop the right wing and or jerk without me moving the stick. And when correcting after this glitch I seem to have complete control. Thought it was maybe wind, but no as it did it again with little to no wind, after acouple min. I landed and checked everything on the plane except in the wing (extension plugs) also did range check with and without engine running and it all checked out great at 100'+ I also replaced the batteries in the trans. and onboard battery, well I quick charged the onboard but it tested ok before that.. And my Freq. was clear.. But samething on my next min. or so flight... Guess I'll pull the wing servos and look at the connectors/wires.. Any other things to check do.. Plane has not crashed and RD 8000/pack is under 9mo. old and have been checked once already by airtronics about 5mo. ago after I dropped my radio on the carpet and broke the throttle gimbal:-( Thanks in advance for tips/help... Have a Great New Year People!! |
RE: Tips and thoughts:-)
It will be hard to say ... my SU31 does that a lot and I could not get to the bottom of it. On another set up I got it bad and I lost 3 planes ... found out my 'glitch' was caused by my RX antenna being cut in half (always make sure you have something to take the strain off the antenna, use a button or old horn to keep the antenna being pulled out of the plane). That causes low range and when the ends touch it causes a glitch. Just my 2 cents ...
Hi again tIANci... The ant. wire is fine, fully extended and has strain
relief(horns) at both the inlet tube and exit at tail wheel from the begining of my 4* life. Which I hope will continue for a long while more:-)... But I'm thinking maybe not... now:-( |
Suggest checking radio with engine running, and do it at all throttle settings. Had similiar situation, couldn't find problem, passed range check, but turned out that as you increased throttle, servo moved as well. Turned out that servo lead had rubbed on mounting screw and worn thru insulation. Wires would only short when vibration from engine moved them. Very puzzling and almost lost airplane over it.
Andy |
I lost a 4* 60 with identical symptoms. It done the exact same thing as yours just before the ailerons locked into full throw position and it rolled over and went in. Post crash revealed the servo extension connector inside the wing had a bad connection. Since I was using a Y harness it affected both ailerons causing them to lock into one position.
WCB.. Bad connection??.. wires pulled out of connector, chafing bare wire?
I just removed the receiver and checked all the wires/plugs etc.,( I'm using two channels only because I wanted to see if flaps would help flat spinning of the 4*...No) all looked in perfect shape including ant. and ant wire is as far away as possible. So I stringed and taped the wire of the wing servo and pulled the rt. side out, again all looked to be brand new and fully connected.. So I moved the wing somewhat ^%$#*&^ and the weight of the servo wire started it sliding off the wing.... And #@*(&%$^... NO.. I did not tie something to the other side of the string:-( I made it Soooo long, I thought it would be OK and it was, except it was not long enought to go from the table to the floor and still say in the wing... Anyway at least I know all is good with the Rt. side, I'm still going to ohm the wires and move them around just in case.. But the way it looks, I don't think I'll find anything wrong.. So now starting to think how big a cut I need to make so I can get the wire back in:-( And because of that... I will continue tomorrow.... Darn another no fly day.... Andy... I was moving the throttle (while airborn) when I had the problem just to see if that had anything to cause it.. And you know it did seem to stop the problem when I was at idle but I really did not test that long.. It's kind of a funny feeling:-( So I landed.. But I did cycle the engine along with moving the ailirons with the trans ant. down from about 50' on the bench and no problems?? Well if you read above... my Rt. side looks to be good But because I was so dumb.... I had to stop and will continue tomorrow:-( |
My connection "looked ok" too, but when I wiggled the servo leads at the connector the ailerons starting going crazy then locked into position. Apparently the connector at the servo extension was bad.
Raideron, did the " glitch " happen near the same spot area over the ground each time ?
The reason I ask is the field where I fly has some violent updrafts and down drafts on calm days in one area. The first time I hit them I just knew I was having a mechanical malfunction or a radio hit, until I realized that no matter what the servos did my plane was not capable of maneuvers like the ones it was doing. Just a thought. |
Thanks again WCB.. I still need to check it that way.. After what
happened I had to call it a day.. I hope it's something simple as that.. Because now that I think about this... I remember the last time I was out flying and moved the flap switch while on the bench my ailirons went up instead of down... And that should not have changed.. Anyway the checks will go on :-) and if nothing is found guess I'll have a longer wait to fly again:-( |
SeaDog, As a matter of fact it was about in the same area(2)..
But I thought the same thing, So I was trying to remain calm and fly in that area.. But than a fellow member saw what the plane was doing on my third try and he said it was not the wind, needless to say I got alittle more nervous so I just came in for a landing to take it home and check it out before trying again.. I must admit I've flown this plane quite a lot, in different conditions and I have never have it act the way it did today... |
Yes, better safe than sorry.. Even though I had been warned about the updrafts months prior to the event I still almost wet myself when I saw my plane try to flip its self onto its back while shooting strait up like a rocket. [&:]
FWIW I have found that at my field the updrafts run along the tree line, and down draft is common where the water is standing after rain, or sometimes the end of the runway where the concrete meets the grass.[X(] Anyway where there's an updraft, there will be a down draft too, that's why I prefer a breeze. when I fly[8D] |
Thanks SeaDog... Well I still have not made it back to working/testing
on my 4*60.. But will...., I did use my radio on my Dazzler yesterday with no problems... But I use a "Y" on the Dazzler, And two channels on the 4*.... And today it's raining in the desert.. Didn't think it did that here:) In any case I still have not made it to work on it yet.. But looks like I have time... And I'm still trying to find a cheap Twist/ 70-82 4c along with floats for my Avistar:-) |
You may have a pot in the one servo going sour. Try swapping in another servo. See if the problem goes away. If It does then you have it. You may also want to try a heavyer guage wire in the extension. Sometimes on long extensions you get too much resistance and the servo's cannot draw enough power and kinda go nuts. I hope this helps.
Mark Shuman |
Thank's Mark.. If I don't find any other problems I might try switching
the servos.. I have the bushing one's on my Avistar, Don't think I'll try the ones in the Dazzler there the non "Z" type... But.. Anyway thanks... But one thing wounldn't the servo do the problem when I was testing it on the bench... All worked great while on the ground, Trans. ant. down from about 100' with and without the engine running???? Anyway, It maybe a little longer before I get back to it.. Have to head to Vegas for more work on the "bosses" back and we may stay a few days:-(.... |
Sounds to me like a problem with corsion in the aileron extensions or a servo pot going bad.
Both of those problems can cause a servo to act funny at odd times, including working fine most of the time, but randomly jittering, or missing center or responding slowly once in a while. On your aileron extensions, are you using gold connectors, or are the connector pins and sockets silver in color? Gold connectors don't corode, so they are better when you won't be plugging and unplugging frequently (the plugging and unplugging can rub the connectors clean somtimes). I'd pull the servo(s) and the extenstions. Are you using 2 extensions per servo? One from the RX to the wing (where you disconnect it), and another inside the wing? If so, you might consider cutting the servo lead and soldering on long leads that go all the way through the wing, getting rid of one connection (and failure point). Obviously, if you aren't comfortable with a soldering iron, this isn't the time to learn. |
Oh, as for getting the aileron lead back in the wing... Try gluing a bit of string to a 2-56 bolt and holding the wing up on a wingtip. You should be able to drop it down the wing. You might have to shake the wing around a little to get it to bounce the right way, but with a little work, you can get a string back through there. (been there, done that)
Hey Kirk. Yeah two gold extensions per... I may solder it.. Good point. I
hope the pot isn't bad, there only about 7 months old, But they did get quite a work out in that time, 3-6 flights 3-4 days a week.. Is there a way to test the pot??? Hate to just randomly change them if I don't find anything else wrong.. I do know the rt. ext. is not corroded and it all looks brand new.. I alsohad practice on dropping the string out then back in while I was putting the 4* together... Seems like I would have learnt better |
1 Attachment(s)
Well, Just an update.. I'm sure noone wants to here:-).. Well I inspected
checked, pulled and twisted wires/connections and all just works fine while bench testing, nothing really found.. Did find Lt. wing extension "slightly" pulled apart... Not sure if it happened while taking it out.. But anyway I found something so guess I'll give it a try... Wish me luck people.. Not sure when my test flight will be since it's suppose to rain for the next three days here in the desert... But the plane is on the charger and as ready as I now can get it... So what the hey, we're going for it:-) |
Dang it's just me again... Can't fly... Result... More posting:-(
Well this should be my last on this subject.. Hey now be nice... I made it to the field before the rain:-) My flight only lasted about 5 minutes:-(.... and my glitch reared it's awful self again... Darn... Anyway we landed with no problem... So now "all" my radio gear is heading to Airtronics for a "free" check up.... Is it a guarantee that they will find the problem???????????????? Have a Great one All..... Be Safe and Have Fun... Me I'm waiting:( |
| All times are GMT -8. The time now is 12:31 AM. |
