RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Basic tools for kits (https://www.rcuniverse.com/forum/beginners-85/2569214-basic-tools-kits.html)
samolot 01-21-2005 10:45 PM
Im a beginner, who for his birthday want three kits (not so cheap all together). I will be worried about angines radio later, but for now i just want to nkow which tools are always needed to complate any project.
If a list will be presented, i will be very thankful.
Thanks alot,
Michal
bryris 01-21-2005 11:04 PM
RE: Basic tools for kits
Someone might beat me to this, but here are a few.
CA glue, medium and thin
Razor saw
Modeling knife /w several replacement blades
A bunch of T-pins
Wax paper
Wood filler
A flat surface thats big enough for a wing panel, at least.
That'll get you started on a kit. You might need more esoteric tools as you go, soldering iron, heat gun, covering iron, etc.
Cyclic Hardover 01-22-2005 12:28 AM
Get a package of one sided razor blades. THey come in handy for everything to include covering. They sell them in packs of 100 for around $5 or so in stores like Lowes or Home Depot or similar.
That wax paper he mentioned is placed over the plans so that the glue from the plane does not stick to the plans and rip them all up.
DBCherry 01-22-2005 09:17 AM
Here's a standard answer I've used for this question a couple times:
Material for Building
Glues: 30 minute and 5 minute epoxy, with something to mix it on and with, (old plastic lids and wooden coffee stirrers, plus small plumbers' acid brushes). Thin CA. (Not "Superglue".) You can substitute wood glue for the CA, but it adds time to the build.
Tools: XActo knife and extra number 11 blades. (Buy a box of 100, it's cheaper and you'll use them.) Razor saw; Kona or XActo. Kona is better. Steel straight edge, 18". A ruler will work but.... Sanding block and various grits of sandpaper. (80, 120, 200, 400.) Screw drivers, small and medium sizes, both flat and phillips types. Pliers, needle nose and regular. (At least one pair with side cutters for wire.) A good set of Allen or hex wrenches. (IMO, Ball drivers are a bit better if you can find a good set.) A "Dremel" type rotary tool will help a lot if you can shell out the extra dollars.
Covering tools: A sealing iron. A Trim iron will help too if you can swing both. A Heat gun made for covering. (Blow dryers don't really get hot enough.) More of those #11 blades for your XActo knife if you didn't buy the box of 100.
Check the kit (or ARF) contents. Most will have a list of extras you'll need to buy; like wheels, fuel tank (& size), fuel line, etc...
By the way. You should buy the engine and radio equipment when you get the plane. You'll need them all to finish the plane, and in some cases, you’ll need them to get started. Buy an engine on the larger size of the recommended range.
