Engine Question
What is the difference between a FX, AX, or whatever X they may have? Also what does the number in front of it mean? is it the power or the size? or a little bit of both? for example: .20 .40 .60 .90.??
I can seem to find a thread on engine basics Thanx |
RE: Engine Question
The letters are manufacturer designations. Some have ball bearing, some are ringed where others are ABC (aluminum, brass, chrome) construction.
The number is the displacement in cubic inches. a .50 or 50 is 1/2 cubic inch cylinder displacement. |
RE: Engine Question
Try this http://www.masportaviator.com
Click PRI FLY which is primary flight training. There you should see lots of beginner articles including Engines 101 and Engines 101 part 2. |
RE: Engine Question
Excellent site, Thank you.
RE: Engine Question
My pleasure. Where are you in Jersey? I grew up in Philly and spent most summers in Ocean City NJ.
RE: Engine Question
hey, Union City NJ.. 10 min from NYC.. Not too far from philly.:D
RE: Engine Question
I've only seen AX, FX, and SX on the OS engines...
The AX and FX seem to be their high quality "ABL" (Advanced Bi-Metallic Liner) engines with ball bearings. The SX engines appear to be bored & stroked versions that have higher displacement in the same size engine (.50 SX is same size as a .46 AX/FX, .32 SX is same size as .25 FX), and the .50 SX is actually a ringed engine, instead of an ABL engine like the .46 AX/FX. OS also makes an LA series, which I believe are lapped engines (no liner) with bushings (instead of ball bearings). |
RE: Engine Question
The LA series are ABN, bushing engines.
| All times are GMT -8. The time now is 11:46 PM. |
