RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   battery charging question (https://www.rcuniverse.com/forum/beginners-85/2605000-battery-charging-question.html)
mrbass111 01-31-2005 12:11 PM
can a 12v hobby box battery be charged with a regular (car/boat type) charger?
raideron 01-31-2005 12:15 PM
RE: battery charging question
Sure can, At least that's how I charge my field battery, But I do use
the 2a charge... No problems in 9 months while using my auto charger/
maintainer about every two weeks...
Geistware 01-31-2005 12:52 PM
Yes it can, the problem will be that at times, you need to get the battery to top out at about 14.5 volts. I could never get my car charger that high.
mrbass111 01-31-2005 12:55 PM
does it matter if its gel or acid?
Fastsky 01-31-2005 02:16 PM
I have charged both types with a standard 12 volt 3 amp charger with no problems. If its one of the high output chargers that puts out 6 amps or higher I would avoid using it. [8D]
