Comment & Complaint
Hello All,[:o]I'm new to ordering plan's off the internet, I found a company that sells a CD called Ultimate R/C Aircraft, It has 1,401 Plan's on it so I ordered it, When it arrived, I hurried to my computer with excitement only to be disappointed when I opened the package, Instead of receiving the 1,401 R/C Aircraft Plan's, I received another CD called Extreme Woodworking Patterns, with 8,500 woodworking projects, I've sent 5 E-mails to the company in the past week and a half and still haven't received a reply, I'm not saying the company is bad, but I would use caution before I'd order from them again. The Company in question is listed below.
Sincerely, Michael[&o][&o][&o] Blue Mercantile 46577 Yale Rd. Chilliwack, B.C. V2P 2R6 Canada |
RE: Comment & Complaint
Did you try phoning them? I realize it costs more and you also may not have a number. Try 1-800-555-1212 (800 directory assistance) and see if they have an 800 listing for the company. If paid by credit card, have them stop/reverse the payment. [:@] Good luck.
i wish you luck to.
I would build from plans so i had a diffent plane than everyone esle. that peaked my intrest, then i just seemed to easy. I also figured it would end up being a bunch of 3views. but good luck and keep us informed |
RCM and MAN magazines (and others) have plan services that are reliable and you should be able to find something to build that you would like. Give them some thought too, they both list their plans on the web at reasonable costs.
ORIGINAL: bruce88123 RCM and MAN magazines (and others) have plan services that are reliable and you should be able to find something to build that you would like. Give them some thought too, they both list their plans on the web at reasonable costs. Thanks, Dave Olson |
Try these for a start:
http://www.rcstore.com/rs/general/plans.asp?catego=PL http://www.rcmmagazine.com/e/env/000...ore-plans.html Other magazines have listings also. I have built from RCM plans and they are of high quality as I am sure are the MAN plans. Others can give you more sites I am sure, these are the two I can think of in a hurry. |
ORIGINAL: w4mwk ...Instead of receiving the 1,401 R/C Aircraft Plan's, I received another CD called Extreme Woodworking Patterns, with 8,500 woodworking projects... |
Hi Paul,
I did look thru the projects, No 1,401 Aircraft plans, Not even one. Thanks, Mike |
| All times are GMT -8. The time now is 03:29 PM. |
