RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   OS Engines (https://www.rcuniverse.com/forum/beginners-85/2733203-os-engines.html)
vdubin64 03-06-2005 12:56 PM
OS Engines
How long has the ax been in production and how do they perform? Are they bearing or bushing?
Any repley would be wonderful !!! Thanks
vdubin64 03-06-2005 12:59 PM
RE: OS Engines
JohnBuckner 03-06-2005 01:01 PM
RE: OS Engines
I think they have been around a bit over a year now and it is a ball bering supported crank.
John
Pilot Chad 03-06-2005 01:03 PM
RE: OS Engines
also, they are great engines from what my instructor told me. I plan on getting one soon
vdubin64 03-06-2005 01:10 PM
RE: OS Engines
Thank you for your imput newb.
ejp67 03-06-2005 01:23 PM
RE: OS Engines
OS has been around for a long time. They been around since the 70's at least!!!!!:D
vdubin64 03-06-2005 01:25 PM
RE: OS Engines
what about the mds 46 does anyone own one??
высшее одно 03-06-2005 02:31 PM
RE: OS Engines
I have had my AX for a little over a year. It runs nice, and puts out a good amount of power. It is a ball bearing engine.
JohnBuckner 03-06-2005 06:01 PM
RE: OS Engines
ORIGINAL: ejp67
Actually I beleve Vdubin's question was how long has the 'AX' been around. OS has been marketed in this country since the late fifies and I have a few including an OS type 11 pulse jet engine that I purchased at a LHS in Hollywood.
John
Campy 03-06-2005 06:05 PM
RE: OS Engines
ORIGINAL: vdubin64
You must be referring to the "Mostly Don't Start" or "Metal Door Stop". [8D]
Do a search on MDS here and form your own conclusions.
JohnBuckner 03-06-2005 06:06 PM
RE: OS Engines
Vdubin If you do a search over in the glow engine forum you will find a lot of info about the MDS, both pro and con. They seem to have had a somewhat tarnished history and I don,t beleve Horizon Hobby still imports them.
John
Ed_Moorman 03-06-2005 06:21 PM
RE: OS Engines
At this point, the only engine in the OS AX series is the .46AX. It replaced the OS .46FX.
The AX is a top-of-the-line, mid-sized engine. It has good power. It is very high quality, very reliable, easy to start and easy to adjust. It is more expensive than the Chinese engines of the same size and you'll need to make the judgement at to whether it is worth the extra money.
ahuod 03-06-2005 06:24 PM
RE: OS Engines
Sorry to change the subject,but do you think an OS.91 FX benefits enough from a Perry to justify doing it?
LuckyArmpit 03-06-2005 07:02 PM
RE: OS Engines
I have two OS .46 AX's. Wasn't all that much to break them in. And basically, once you set the high end needle a few clicks towards the rich end at max throttle, you never really have to fool with it. I run both of mine on Byron 10% fuel....although I may start using 15% (the green color'd stuff). I also run an 11x6 prop on them. They are about 20 bux more than a TT Pro and Magnum but OS has just a tad bit more quality built in.
Dave...
RCKen 03-06-2005 08:40 PM
RE: OS Engines
ORIGINAL: ejp67
Oh, they've been around just a little longer than that.
[link]http://www.osengines.com/history/ostimeline01.html[/link]
They started making engines in 1936, but I don't know when they started marketing in the use.
