RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Cutting Servo Openings (https://www.rcuniverse.com/forum/beginners-85/2738987-cutting-servo-openings.html)
Harleyflyer 03-07-2005 09:05 PM
when I go to cut out the servo openings on an ARF, is there any need to use a heat gun to shrink the fabric before I do this? In other words, if there are any wrinkles in the fabric should I use the gun before I cut the openings or does it not really matter...whether I need to shrink the fabric before of after I cut the opening?
Thanks.
piper_chuck 03-07-2005 09:28 PM
RE: Cutting Servo Openings
If I need to cut an opening I don't use a heat gun, but I do iron around the edges before and after cutting. This helps keep the covering from lifting.
DBCherry 03-08-2005 06:14 AM
Agree with Chuck. Iron the covering down around the opening before cutting.
I also leave some excess around the opening and iron it down into the opening and under the edges.
Dennis-
MinnFlyer 03-08-2005 06:40 AM
Ditto to both
