RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   pull pulls, what to use for cables? (https://www.rcuniverse.com/forum/beginners-85/278348-pull-pulls-what-use-cables.html)
Hummve 09-22-2002 02:36 AM
I need to know what i should use for the cables on my pull pull system it is hooked up so it goes from my rudder to my back landing gear. :confused:
KCFlyBoy 09-22-2002 04:51 AM
I use Kevlar the coated type it does not stretch and it won't cause radio interference like steal can.
BingoFlyer 09-22-2002 03:09 PM
I use braided steel fish line (leader) that is plastic covered. I have never experienced radio interference using it. I have a Jenny that all the controls are pull/pull even the ailerons, very scale like, and it has a lot of steel cable both inside and out.
Rodney 09-22-2002 07:10 PM
Like Bingo above, I use nylon coated braided steel fishing line and have never had a problem with interferance. So far on 5 1/4 scale jobs and several smaller models.
Equest 09-22-2002 08:01 PM
You can use Bingo Flyer and Rodney's system. I think a better alternative is to use the purposely built pull-pull kits made by Dubro or Sullivan. These kits will come in a 2-56 or 4-40 size, your choice. Also, all of the components/hardware are provided in these kit. They are worth the extra $$.
TerrellFlyer 09-22-2002 11:48 PM
I use the Dubro pull-pull kits.
Have a goodun,John.
Hummve 09-23-2002 02:31 AM
Cool thanks i am going to go with the Kevlar or cable, have to think about it thanks.
