RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   What fuel for 4 cycle (https://www.rcuniverse.com/forum/beginners-85/2991027-what-fuel-4-cycle.html)
cyworld 05-19-2005 02:52 PM
Hi
I bought a Saito72 4Cycle engine and an O.S 70 4Cycles engine.
Can I use Power master 15%fuel? I am using for 2 cycle engine.
I don't have a manual for those engines.
Please let me know.
Thank you
Fragmentum 05-19-2005 02:54 PM
RE: What fuel for 4 cycle
15% fuel is a good choice, but not less than 18% synthetic only oil is best.
carrellh 05-19-2005 03:09 PM
Here's a link to the engine
http://www.horizonhobby.com/Shop/ByC...ProdID=SAIE072
On the left side of the page is a link to the manual:
http://www.horizonhobby.com/ProdInfo...ingles2004.pdf
It's a 1 mb file. Fuel reccomendations are on page 3 (page 5 in acrobat reader)
JohnW 05-19-2005 04:01 PM
The Powermaster 15% will work just fine. It has enough oil. Typically, most pilots will use the same fuel in thier 2S engines and 4S engines. Just beware that there are some fuels labeled as 4S fuels... DON'T GET THAT. They are blended with very low oil and are not suitable for use with most of todays 4S engines. Enjoy your new engines... cheers.
cyworld 05-19-2005 04:33 PM
What a fast information. Thank you all....
I just checked my fuel. I am using Power Master 15%Nitro-18%Synthetic/Casteroil
This is O.K for 4Cycle engine,right?
DaveB 05-19-2005 05:44 PM
Check out your engine's instruction manual to verify, but I have found 2 stroke engines and 4 stroke engines can use the same fuel. I use 12.5 % nitro, 18% synthetic and 2% caster. That formula meets the requirements for the O.S. engines, both 2 stroke and 4 stroke that I have in my planes.
DaveB
raideron 05-19-2005 07:14 PM
cyworld... Your 15% will do great... I used 15% PowerMaster in my YS
63 and it worked good... But then I tried P.M. 20/20 synthetic.... Big
mistake..... I liked it Too Much!!! Now it's the only fuel I use for my 4c's....
EscapeFlyer 05-19-2005 10:15 PM
Your Saito will LOVE powermaster. If it could, it'd reach out and give you a big wet sloppy kiss. :D
Try their heli fuel-even BETTER!!!(for saito)
cyworld 05-20-2005 01:36 AM
Thank you all. I really appreciated.
w8ye 05-20-2005 02:34 AM
I use Omega 15% in everything.
Enjoy,
Jim
cyworld 05-20-2005 09:36 AM
Omega 15%? Is it for helicopter engine?
I use airplane fuel:Power master 15% and helicopter fuel:Cool Power 30% or 15%.
bubbagates 05-20-2005 09:56 AM
Your Powermaster will be just fine,
Now if you really want to spend money and really make that thing purr, Cool power 30% Helli (30% nitro/24% syn oil) will really do the trick.
At that point, the engine will find a way to climb out of the plane and give you a big sloppy wet kiss :D
For the person that has the YS. Try Wildcat 20/20 or even the same cool power 30/24 Heli. YS engines love nitro and the more the merrier. They are not real fond of castor because it can plug the regulator. The book says you can use it but no more than 2% castor blended with synthetic, but actually recommend full synthetic.
I use the Wildcat 20/20 in everything glow I own (slowly switching to gas). On the rare occasional I will buy a gallon of 30/24 Heli for the YS110 if I run low on Wildcat
OS160FX
Saito100
YS110
Liberator 05-20-2005 10:02 AM
Bubba,
(wipes the slobber off) You are so right, I have been running that in my OS 50 and I am also going to run it in my Magnum 91 when I put that in my P-40. It's a great fuel. About $6 or so more per gallon, but I think its worth it.
Tom
tIANci 05-20-2005 10:41 AM
Oh yes ... Cool Power 30% heli fuel for YS engines! :)
JohnW 05-20-2005 01:34 PM
Ditto on what bubbagates said. The only glow fuel I currently use is CoolPower 30% heli, then again all my glow engines are YS. YS engines LOVE this stuff. Monster power, great response. Only down side is YS engines LOVE this stuff in quantity... I only get 5-6 flights per gallon with my 160DZ.... can anyone say fuel hog? Oink!
bubbagates 05-20-2005 01:43 PM
And I thought my 110's drank fuel...[X(] But you're right, you just can't beat the output they have even on lower nitro contents (down to 15%). That's one of the reasons they are so hard to find other than the factory just cannot keep up with the orders. It took me 1 year (that's right 1 year) to get my second one. Just as soon as they come in they are gone and some places won't even sell them unless it's part of a package. But OOOHHH are they sweet. Nice and light, and swing nice big props.
But they are expensive...[X(]
tIANci 05-20-2005 02:59 PM
I get pretty good mileage on my YS110, I fly the F90 and I get about 20 mins of flying time from one tank. I think its a 12-14 oz tank. The YS110 gives a lot of power without the muffler, I am flying w/out one, just a diverter to clear the cowling.
proulxlaw 06-03-2005 01:38 PM
Tianci:
What does your plane weigh and are you flying it at or near full throttle to get the 20 min. flight times on the 12-14 size fuel tank? What fuel did you say you used to achieve this?
tIANci 06-03-2005 01:48 PM
Flieger - the Funtana 90 is a slow plane in the sense that you do not fly it that fast. I fly at about 40% max on level flight. When I go vertical its 100% throttle and prop hangs are at about 55% throttle. Tank is the standard one ... I think about 14 oz. Fuel is Cool Power 30% heli. I did run a TT120 2C also and I could get about 8 mins flight at about 125 ml, not sure how much in oz. That is on my 1/4 scale LASER 200.
MinnFlyer 06-03-2005 02:51 PM
I run Cool Power 15% in my 110FZ, and I can't imagine that it could possibly run better.
I'm certainly not going to spend more on fuel for better performance - That would be like buying diamonds for a woman that loves Cubic Zirconium! :D
tIANci 06-03-2005 03:02 PM
Minn ... what are you getting with your 15%? I might go back to 15% as I moved to 30% just after break in on 15%.
cyworld 06-03-2005 04:47 PM
I have a Saito 91 and O.S91 4Cycle engine,also,O.S46 and Webra 120. Those company recommend 10%~20%.
Is it O.K use 30%helicopter fuel for those engines?
