RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   hinges (https://www.rcuniverse.com/forum/beginners-85/2991747-hinges.html)
madmanmikie 05-19-2005 06:46 PM
hinges
Hi was woundering what glue you use for installing Robart hinges . 4 per aleron. thanx
Pilot Chad 05-19-2005 06:51 PM
RE: hinges
I think they are CA hinges. So just use CA
Rubberduck 05-19-2005 06:59 PM
RE: hinges
Robart hinges are not CA hinges. RCU has a "How To" for installing Robart hinge points here --> http://www.rcuniverse.com/magazine/a...article_id=269 and the associated RCU discussion thread (which talks about different types of glue you can use) is here --> http://www.rcuniverse.com/forum/m_13...tm.htm#1378983
RCKen 05-19-2005 07:25 PM
RE: hinges
They definately ARE NOT CA hinges. Please read over the links that Rubberduck posted above.
Pilot Chad 05-19-2005 07:31 PM
RE: hinges
Sorry. I am an idiot....
bruce88123 05-20-2005 07:32 AM
RE: hinges
Robart also has instructions on their web site: http://www.robart.com/how_to/hinge_points.aspx
Enjoy. I like them. This is one place where a lot of people do use Gorilla glue or similar. :)
bruce88123 05-20-2005 09:25 AM
RE: hinges
Chad- you are not an idiot. You ARE new at this with limited experience. Just be sure of what posts you answer and all will be fine.
Campy 05-20-2005 10:16 AM
RE: hinges
A tip for you on the Robart hinge points or Klett (nylon ) hinges.
Take a toothpick and put a SMALL amount of vasoline on the hinge joint prior to installing them. Any adhesive that may seep out of the hole will not adhere to the hinge joint.
madmanmikie 05-20-2005 08:12 PM
RE: hinges
Thank you! to everyone that replyed, I went to the links that rubberduck posted, it work just fine, as to how the links explained, but the only difference I made was, is that I used vasoline in the joints instead of 3 and 1 oil. Thanx again everyone
bruce88123 05-21-2005 07:43 AM
RE: hinges
Didn't have any vaseline around last time I installed some so I used hand lotion. Worked fine, :)
