RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   prop balancer (https://www.rcuniverse.com/forum/beginners-85/2994253-prop-balancer.html)
bigyellowbird 05-20-2005 02:27 PM
prop balancer
i just got a new (used) top flight magnetic prop balancer. what a neet toy!! but no instructions on how to balance the prop.i have a black (composite) master airscrew 11x7 on there and yes, the heavy end fell to the bottom. now what? sand on the back side? front side? add weight? what do i do to a wooden prop? any info would be helpful!! THANKS IN ADVANCE!
bruce88123 05-20-2005 03:30 PM
RE: prop balancer
Try this:
http://www.top-flite.com/manuals/topq5700-manual.pdf
http://www.top-flite.com/parts/topq5700pl.html
Then practice using your search engines some. Pretty easy to find. :D
Glad to help though.
raideron 05-20-2005 03:54 PM
RE: prop balancer
bigyellowbird... I tape and spray paint the tips and just add more
paint to the light side... Sometimes it takes me a few tries to get
it balanced... But I'm getting better at it now:-)
Plus you'll see the tip better when the engine is running....
Campy 05-20-2005 03:58 PM
RE: prop balancer
I would not recommend sanding. Sanding could POSSIBLY weaken the blade.
You are safe by adding paint or clear coat to the light blade.
