RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   sanwa tx and multiplex RX? (https://www.rcuniverse.com/forum/beginners-85/3096929-sanwa-tx-multiplex-rx.html)
burndred 06-22-2005 03:28 AM
hey everyone..
does anybody know if it is possible to use a sanwa 35 meg fm 6 channel tx with a multiplex micro ipd receiver
thanks
Rick
StarskiPZ 09-22-2005 10:21 AM
RE: sanwa tx and multiplex RX?
Hi,
Should work fine on the Sanwa non-PCM gear..
see
http://www.mpx.speedkom.net/cms/vors...tip_ipd_gb.pdf
However, i have heard that on Futaba Tx, there have been issues with the use of The IPD..?
Again this could be that some of the advanced Tx units can transmit on either PCM or PPM
IPD works only in PPM transmission
hope this helps?
Anyone else using the benefits of the Multiplex IPD???
hhhhhhhhh 09-23-2005 01:38 PM
yea it should work fine:Di done my sanwa to a futarba recever and it worked most transmitters work with any recevers:D
