RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Starting a gas engine... (https://www.rcuniverse.com/forum/beginners-85/3098569-starting-gas-engine.html)
britbrat 06-24-2005 07:33 AM
RE: Starting a gas engine...
Most likely, the high-speed mixture is too lean & the low-speed mixture is about right. when the engine transitions from the low-speed mixture to the hi-speed mixture, (more or less at about 1/2 throttle) it goes lean & dies. When you fix the high speed mixture, you will probably have to re-adjust the low-speed setting again.
