RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Changing monokote (https://www.rcuniverse.com/forum/beginners-85/3180-changing-monokote.html)
rajul 06-01-2002 08:25 AM
Changing monokote
I am planning to change the monokote covering on my entire plane to a different color scheme. How do I strip monokote without leaving any blemish or adhesive residue on the wood ? Do I need to sand the wood again or any other surface prep before I cover ? Highly appreciate it if someone with experience could offer some hints......................
FHHuber 07-25-2002 09:05 AM
Changing monokote
The cooler the covering, the better it seems to peel off without leaving any adhesive. work on it in an air conditioned room for the strip-down.
The knife scraping works for some people to get rid of what still sticks... I prefer to sand it off. It does clog up sandaper...
If its contact "paper"... the sticky goo glue is a pain in the tail. You'll have to sand it off and use up a TON of cheap 180 to 220 grit paper. OR... :D OVERHEAT the covering before stripping, let it cool and the glue hardens up. The covering will be a bit harder to strip off... but the glue will come with it. ;)
rajul 07-25-2002 09:54 AM
monokote bashing
Hi guys ! I've seen another forum where monokote seems to be loosing popularity. Everybody seem to prefer ultrocote for less bubbles, easier removal, and equal strength. I don't have enough experience to comment, but what do you guys think ?.......:)
