RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   4 Star 40 CG? (https://www.rcuniverse.com/forum/beginners-85/3225927-4-star-40-cg.html)
myork 08-02-2005 09:25 PM
4 Star 40 CG?
Just picked up a Clipped wing 4 Star 40. Just wondering where the CG should be. The wing is clipped 6 inch's and the rudder control surface has been inlarged.
Pilot Chad 08-02-2005 09:49 PM
RE: 4 Star 40 CG?
Copied Directly form the Tower Hobbies Website
SPECS: Wingspan: 59-3/4" (1518mm)
Wing Area: 604 sq in (39 sq dm)
Weight: 4.75-5.25 lb (2.1-2.3 kg)
Length: 47" (1194mm)
Airfoil: Semi-symmetrical, low-wing
Center of Gravity: 2-15/16" (74mm) Back from the wing's leading edge
Control Throws-
Elevator: Up & Down 1/2" (13mm)
Rudder: Right to Left 1" (25mm)
Ailerons: Up & Down 5/8" (11mm)
bruce88123 08-03-2005 08:40 AM
RE: 4 Star 40 CG?
Now, that is the way to do it Chad. A little research. :)
DamonTX 08-03-2005 08:58 AM
RE: 4 Star 40 CG?
Myork....are you asking whether or not the CG would change on a plane with those mods? If so the answer is no.
myork 08-03-2005 03:02 PM
RE: 4 Star 40 CG?
No I figured it wouldn't change with those mods. Sorry guys I forgot about getting on Tower and Looking it up. I'm new to the Hobby so I'm still trying to get all my info resource's stuck in my head. :D Believe me I know all about the search button. I have almost 600posts on ls1tech.com.
Thanks alot
Matt
bruce88123 08-03-2005 03:08 PM
RE: 4 Star 40 CG?
No problem. Any question - any time. We'll have an answer. Who knows, we may even be correct. :D We're all still learning here too.
Chevalier 08-06-2005 11:28 AM
RE: 4 Star 40 CG?
Just balanced on today, the plans for the 4*40 shows the center of gravity on the main spar.
