RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   oops.... (https://www.rcuniverse.com/forum/beginners-85/3238133-oops.html)
txaggie08 08-06-2005 09:33 PM
oops....
1 Attachment(s)
for some reason i went to take off earlier, the plane took a cartwheel as it lifted off, and i looked down and the radio was off....... im realy at a lost how my radio got turned OFF in the middle of a flight. at least its nice neat and clean on the break though. im going to glue it back in, then run 1/4 inch stock on the bottom and some thicker tri-stock up top
**edit**, btw, all i have is some five min epoxy, should i use it or wait and get some fifteen or thirty?
Grant-KS 08-06-2005 11:24 PM
RE: oops....
Sorry about the accident. As for the epoxy, I wouldn't take any chances on the tail feathers like that. I'd use at least 30 min. epoxy.
britbrat 08-07-2005 10:23 AM
RE: oops....
5 min epoxy is not fuel proof -- don't bother with it.
Medium &/or thick CA will work just fine, as will 30 min epoxy, as will Probond/Gorilla Glue.
tychoc 08-07-2005 11:28 AM
RE: oops....
txaggie08: Sorry to see you had an accident[:o]
Looks like a easy fix though. I would use 30 min expoxy. That gives you enough time to make sure everything is aligned correctly.
-tychoc
txaggie08 08-07-2005 01:29 PM
RE: oops....
ok thanks :)
whats realy killing me....i dont know why it happend. It literaly snapped over about halfway through a nice level take off into a dead on head wind(not shifting at all). i look down and the radio is off........i dont understand what happend
TexasAirBoss 08-07-2005 10:30 PM
RE: oops....
The clip on the neck strap can bind. It may have popped free and flipped the switch. Now, many manufacturers place the On/Off switch in the lower corner to avoid this. You wouldn't be the first person this has happened to.
ICE_MAN 08-07-2005 11:17 PM
RE: oops....
txaggie08 08-07-2005 11:38 PM
RE: oops....
no kneck strap(forgot it on the table. I think i found the culprit....there was a piece of rubber band wedged under the switch
