sk 80 glow engine question
I got one of those and put it on my big stick, the engine has a lot power but i do not fell it okey, when it's in idle by few seconds and open the gas, it stars to !QUOT!blablus!QUOT! i mean almost it die. Somebody have experience with?
thanks |
RE: sk 80 glow engine question
Sounds like the idle mixture is not set right.
Cheers |
Hi pejuve , I have one on my Modeltech P47. Have you had a chance to get some rpm numbers and which prop are you using? I am only getting 11,000 on an APC 12-6. Sounds low to me?!? The throttle barrel was also sticking today so I am going to take that apart and take see whats happening. Also the instructions state to start the engine with the needle valve set at 1 3/4 turns out. Mine won't even start at that. I need 2 3/4 turns out to start and it will die if I close it past 2 1/2 turns. Are the instructions wrong or did I juist get a lemon?? Thankx for any feedback. [8D]
sounds liek its rich and is loading up.....
| All times are GMT -8. The time now is 05:00 AM. |
