RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   TURNING A 2 BLADE SPINNER INTO A 3? (https://www.rcuniverse.com/forum/beginners-85/3294316-turning-2-blade-spinner-into-3-a.html)
P-40LUVR 08-24-2005 11:58 AM
How easy would this be ....to cut a 3 1/2 in. 2 blade spinner and make a 3 blade spinner out of it?:eek:
Enlighten me.:D
exeter_acres 08-24-2005 12:09 PM
RE: TURNING A 2 BLADE SPINNER INTO A 3?
that probably wouldn't work,,, the alignment of 2 blades versus 3 are very different... you would need to cut out 3 new openings, not just one....
that would remove too much material.... IMveryHO
britbrat 08-24-2005 02:15 PM
Won't work -- buy one
kiswa 08-24-2005 02:24 PM
Almost positive that would be impossible to do and still have a functional spinner. Just spend the $$ to buy a new one.
cwrr5 08-24-2005 02:38 PM
Not very. Another vote for just buying one.
bruce88123 08-24-2005 03:13 PM
Actually you would only need to cut 2 openings but it would look like crap if it worked at all. Find it difficult to believe worth even trying unless you are really bored.:D It would also be way out of balance and require even more removed to balance. $$$$ the best here.
D Bronk 08-24-2005 03:21 PM
DO it on paper, and you`ll see it will become a dangerous part ,and quite likely to explode..Trace your spinner ,then divide the circle into three equal pieces of "pie",mark the current openings ..Find the center. Mark the width of the new blades,"centered", on top of your three marks on your little blue-print..you`ll get a visual like this..
flyinbryan 08-24-2005 04:09 PM
just buy one
hhhhhhhhh 08-27-2005 03:08 PM
just buy 1 m8:Dlol
Jimmbbo 08-28-2005 12:30 AM
Ditto - don't do it... will be waaay out of balance, and structurally marginal...
