RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   What prop size (https://www.rcuniverse.com/forum/beginners-85/3318779-what-prop-size.html)
Contama 08-31-2005 10:25 PM
What prop size
Hello I have a super chipmonk 46 and Im putting a Enya 53 4 stroke motor on it. What 3 blade prop should I use for it. The plane has a 61.5 inch wing span and is 49.5 inches long.
mrbass111 09-01-2005 01:49 PM
RE: What prop size
im not a prop expert so i cant help there. but have you tried doing a rcuniverse search of the forums. you can get some good info on older post. see the top of begginners page.
mrbass111 09-01-2005 01:56 PM
RE: What prop size
well i looked in the forums and did not find any thing. the only thing i found was on a goldberg super chip. 45-61. the prop that tower sells with it is a 10x6. if that any help
Woody 51 09-02-2005 08:35 AM
RE: What prop size
A .53 will swing a 12 x 6, 2 bladed prop just fine. For a 3 bladed prop, go down 1 on the diameter and 1 on the pitch. So an 11 x 5. 3 bladed prop will be within the engines capabilities.
But why a 3 bladed prop? Apart from slowing the descent, it won't really give you all that much benefit over a 2 bladed unit. A 2 blade, 12 x 6 will give your excellent TORQUE, which is what you want for climbing an aerobatic model like a Super Chippy.
britbrat 09-02-2005 08:54 AM
RE: What prop size
If it's a Goldberg Super Chippy, a 53 4-stroke will be mighty thin stuff, regardless of the prop. You will need every last ounce of go to be had -- forget the 3-blade.
Contama 09-03-2005 09:22 AM
RE: What prop size
Hello and thanks much for the info Woody I bought a 2 blade 12-6 and going to give it a try THANKS!
