RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Super Stick 60 need help (https://www.rcuniverse.com/forum/beginners-85/3367034-super-stick-60-need-help.html)
suzonka 09-17-2005 09:36 AM
I just calculated 25% of the chord and came up with 3.6 inches from the leading edge, but If anyone out there has one set up they could measure it because it was proven in there flight so maybe I can get a more percise measurement. thanks again. from the leading edge of the wing.Im looking for just stable flight first time, the manuals dont help much ,Thanks email me ASAP
bruce88123 09-17-2005 10:14 AM
RE: Super Stick 60 need help
I don't know, the instructions in the manual seem pretty clear to me. Section 25 on Pg 37 says 1/8 inch behind main spar which is under the back edge of the wing sheeting. IAW the CG is 1/8 behind the sheeting rear edge.
http://www.horizonhobby.com/ProdInfo...700-manual.pdf
Is this enough?
suzonka 09-17-2005 06:47 PM
ORIGINAL: bruce88123
Is this enough?
THANKS BRUCE Ill find that spar
bruce88123 09-19-2005 07:35 AM
All you really need to find is the back edge of the sheeting.
