RE: Best 3 Tips for Beginners first flight?
Well if this pilot was ging to have any luck at all, then I would check and be certain that all of the control surfaces are moving in the right dirrections. This way the pilot will at least have some control.
I would also recommend using lots and lots of stick memory (remembering what way you just moved the stick) So that even if you don't know what the right way is, then at least you know what the wrong way is. I find that this helps me a lot when I get disoriented. Last, I would make this flight as short as possible just so that it qualifys as a flight.[8D] LT-40 |
Buy what you want.....fly what you want......crash what you want!
It's going to happen sooner or later. |
1) take off into the wind @ 1/2 throttle with the wings level.
2)keep the plane well above the ground and close to the field. 3)fly it untill it runs out of gas and try to get it back to the field with the wings as level as possible. |
ORIGINAL: lalaland Here is the scenario..... A kid builds his very first airplane. It has a 2-stroke engine, tricycle landing gear, high wing, and ailerons and he's heading for the flying field! He is bound and determined to fly his plane that day with no experience. When he gets to the flying field there is no one around. But, he remembered 3 things an experienced RC Pilot told him one day if he ever flys it alone for the first time. What 3 tips would you give him? If this were an adult, that would be very different. Most adults realize how easily and quickly serious, life-threatening injury can take place. And, of course, they are adults. If they want to risk life or limb that is up to them. But the question you are asking really is approaching "Is it OK to let a kid go into the field out back and teach himself how to shoot with my .38?" |
1) Simulator. 20 hours of flight time and 200-500 landings should do it.
2) Disciplined pre-flight checks. 3) A positive attitude and a willingness to learn ... when that plane crashes, and it will, learn to pick up the pieces and come back even stronger. - K |
Gotta go with the safe advise to NOT DO IT. but if by accident your plane starts itself and leaps into the air...
don't turn until its at a safe altitude then throttle back to 1/2 or 1/3 throttle then turn with gentle small input movements on the sticks keep it close( but you won't be able to because no one showed you how to trim for stable flight.) if you get EXTREMELY lucky line up on the runway cut throttle to idle but you won't be able to because no one was there to help you adjust the motor for flight..... well I think you get the picture. A students needs to have a trimmed and adjusted plane first time out so he can feel what the plane is supposed to fly like. first flights are usually harry at best on new plane and a first time flyer can't trim it out to fly hands off like an experienced flyer. |
| All times are GMT -8. The time now is 06:50 AM. |
