RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   piper cub (https://www.rcuniverse.com/forum/beginners-85/3590721-piper-cub.html)
skymortar 11-26-2005 10:26 PM
piper cub
hey guys.i have a carl goldberg annivesary piper cub kit.i got this from my brother,it is nib,anyone have any experience with this kit.id like to know if its a decent unit before i spend my winter building it.
DMcQuinn 11-26-2005 11:08 PM
RE: piper cub
1 Attachment(s)
I built one when they were first out (about 1986 I think). Here is a picture. I am still flying this today with OS .61. In the air it flies pretty well. It can be a problem taking off. Sometimes it will ground loop. Landings are not difficult.
skymortar 11-26-2005 11:26 PM
RE: piper cub
would you suggest that engine?if not what should i shop for?clipped or full wing?
DMcQuinn 11-26-2005 11:39 PM
RE: piper cub
This plane will fly on a lot less engine than the .60. A better choice would probably be a 4-stroke in the neighborhood of .50 cu inches. The sound will be better and the bigger prop spinning slower will be a better match for the slow flying cub. Mine will almost go vertical which is not very realistic. I built the full span wing.
w8ye 11-27-2005 12:09 AM
RE: piper cub
Make sure you have a little TOE-IN on your wheels so it is not so wild on take off.
I had a H-9 Cub with a Saito 50. It was a good match. A OS 46 seemed like too much engine and the two stroke didn't like extended low throttle operation like the four stroke did.
A LA 40 is not bad in a full wing one. You have to keep the throttle pretty much open which is good with a two stroke. amazing with a 80" wing?
Enjoy,
Jim
B.L.E. 11-27-2005 06:53 AM
RE: piper cub
I have found that using ultra-lite foam wheels also tames the ground handling of tail-draggers. Their extra rolling resistance and low lateral traction makes asphalt feel like a grass strip. When the centrifugal force of a turn puts the plane's weight on one wheel, the extra rolling resistance of this type of wheel acts like a brake on that wheel, thus helping to stabilize the plane.
