Midstar egine mounting...
Hi, I am coming to the end of putting together a Midstar. The plans show a 4 stroke engine but I am using an OS 46AX. The engine mount , if I am reading the plans right has the engine a bit lower than my other models. To get thisa to work I will have to dremel a slot for the needle valve and also a bit for the muffler to clear. Does this sound right or did I screw up and have the engine mounted too low?!? Thankx for your time, Fast!
RE: Midstar egine mounting...
Hi!
Sounds right! You can of course mount the engine any way you like as long as the universal fuel-tank-to engine rule is followed., Regards! Jan K Sweden |
Minor adjustments like that are just part of the hobby. I don't think I've had a plane yet that I didn't have to use the Dremel to get the needle valve to fit right in it.
I wouldn't worry about it at all. Ken |
Fatsky, I had to notch out a cheek for the needle valve of the OS 52 FS on my Midstar. I remember toying with putting an OS 46 FX on it. I would have had to carve some space for it's muffler. You're probably OK.
i built a midstar with the 46 ax. i did have to cut out a cheek for the muffler. i cant remember what i did for the needle valve its in my garage i havent paid much attention lately.
your gonna love this plane have a ball |
Thankx for the feedback guys! I finished the fuse and adjusted the throws. I am going to pick up some covering for the wing so I can finish that off today. Thankx again and have a Happy New Year!:D
Happy New Year to you too! Post some pics when your finished. It'd be nice to see more Midstars.
| All times are GMT -8. The time now is 02:41 AM. |
