RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Servo Questions (https://www.rcuniverse.com/forum/beginners-85/3720757-servo-questions.html)
tfarmer96 01-02-2006 10:24 AM
Servo Questions
I have all JR equipment and all of my servos are 537s. Can anyone tell me what the difference is in like the 537 vs. 8XX servos? I am assuming torque and perhaps size. Also I have been wondering will any servo (within reason) work with my jr700 receiver. I didn’t know if its like trying to put a GMC 350 intake on a FORD 302 motor.
RCKen 01-02-2006 10:32 AM
RE: Servo Questions
1 Attachment(s)
Tfarmer,
You can use any servo with any receiver out there. You just need to make sure that the wiring of the servo is correct for your receiver. Look at the attached diagram to see the different wiring for the different radios.
Hope this helps
Ken
BarracudaHockey 01-02-2006 11:16 AM
RE: Servo Questions
Most servos with the exception of some older Airtronics stuff will work with any radio.
Here's a comparison chart http://www.fatlion.com/sailplanes/servochart.html but most of the time the differences are speed, torque, ball bearings and gear type (nylon, metal, or karbonite)
KW_Counter 01-02-2006 11:29 AM
RE: Servo Questions
RCKen,
If I switch the + and - wires will it reverse the direction of travel?
KW_Counter
RCKen 01-02-2006 11:41 AM
RE: Servo Questions
KW_Counter,
Not always. It could actually damage the servo in some brands. It's best to make sure that the polarity of the servo matches the output of the receiver. Refer to the chart I posted above. For example, if you have a Futaba receiver then you will want to make sure that the servo you are using is wired like a Futaba servo on the chart above.
barracudahockey,
Even most older Airtronics will work, but usually the polarity on the wiring is reversed from most brands today.
Ken
carrellh 01-02-2006 01:00 PM
RE: Servo Questions
ORIGINAL: tfarmer96
The 537 is a standard, single BB, servo. The DS811 is a digital, single BB, servo. They are about the same size. The 811 is slightly lighter, faster, more torque. The 537 is 26.99 vs 34.99 for the 811.
