need muffler bolts
i was about to finish my fw 190 and find that the tt 25 pro that i bought online had the muffler bolts removed from the package. i cant find the guy i bought it from and i have emailed ace hobby but no reply. any suggestions?
RE: need muffler bolts
i just went to the lhs and bought those. but will os bolts fit into a thunder tiger engine?
Its highly likely they will fit. You may need to cut them off a little? TT are generally copied after OS
Enjoy, Jim |
thanks i guess ill find out when i get home tonight
mark |
i tried the os bolts and they where way to small. ive emailed thunder tiger but have not heard from them either. any other ideas?
Thunder Tiger is one of the worst outfits to get parts from other than Norvell. The engines are great but their marketing policies stink. They normally do not talk to individual consumers. Their attitude is that you should go back to your dealer where you purchsed your engine to get the parts.
What dealer??? If you can find one, they are very helpful. But you didn't purchase the engine from a dealer. Try this guy, he is a dealer and has been most helpful to people on RC Universe. This is his web site but it is not interactive. Get the phone number and call him or use his Email address. http://www.paulsmodelsupply.com/ Enjoy, Jim |
i bought it online from a tampa bay hobby shop. through an ebay store. but it wasnt an auction. and i have no records of the sale cuz i bought it about 3 mos. ago.
Talk to Paul's model supply, he will take care of you.
I've been just going to the Hardware store to get the bolts. But I'm lucky to have such a store near my house. Enjoy, Jim |
If all else fails, determine the size of the bolt (i.e. 2.5 mm, 3mm, etc ) and buy a length of fully threaded rod and some nuts. Double nut one end and solder the nuts and rod together. Cut for the length you need and then use a dremel and cut a slot IN THE TOP BOLT ONLY. You now have muffler bolts the length you need.
I did this in order to fit some muffler extensions to my engine. They work absolutely fine. Cost was about $6 for a 3' threaded rod and another $1.50 for a small plastic pack of nuts. $7.50 for a lifetime supply of muffler bolts in any length you need. |
thanks campy, but i finally got ahold of ace hobby and got like the last to bolts for that engine. tt does not make the 25pro any more
When I need bolts for TT or Magnum .25s, OS .40s & .46s or TT.46, I get all I need from any hobby shop which sells R/C car stuff. Metric, any size and length up to 50 mm.
I read this heading and chuckled...then realized I had read it wrong. For some reason I read it as Muffler Bearings. :D
Thought someone was yankin the chain. |
yes the muffler bearings are right next to the gonkulator switch! :)
or is that the fetzer valve. i can never remember:D |
| All times are GMT -8. The time now is 08:35 PM. |
