NEED 6VOLT 400 SPEED MOTOR OR EQUIVALENT
Can someone help me find a motor setup equivalent to the items listed here? I have done all my purchases thru Tower Hobbies and would like to get these items from them. Hobby Lobby is out of some of the items until the middle of February and I would like to get them sooner and from Tower Hobbies. I need the equivalent of the brushless motor, brushless controller, battery pack, prop and prop adapter, and wheels listed here. Please help, Tower Hobbies has to have the equivalent but I can not find them.
http://www.hobby-lobby.com/telemaster-mini.htm (OR) Graupner speed 400 6v motor (or similar) 2.33 – 1 ball bearing gear drive (or similar) Castle Creations Pixie 20 speed control (or similar) 8 x 6 electric propeller Prop adapter . . . and all other necessary items to go with this. |
RE: NEED 6VOLT 400 SPEED MOTOR OR EQUIVALENT
http://www.towerhobbies.com/electric/index.html
There's the link to Towers Electric flight page. From there you can just have at it. You should find any equivalent set up you choose. |
:( Problem is I don’t understand what the numbers mean, such as Kontronik Fun 500-19 Brushless Motor or Kontronik Fun 400-36 w/4.2:1 Gear Drive or Tower Pro Bm2410-12 970kv
Going to my LHS today to pick up my Mini Telemaster and other gear today so I will check with him to see what he can hook me up with. Thank you!!! |
Are you sure you want to use the old brushed motors and gearboxes? Outrunner brushless motors are not real expensive in this size they are more effecient and you don't need a gearbox. a Himaxx 2812 and 18 amp Thunderbird speed control will cost right around $100. http://www.maxxprod.com/mpi/mpi-26.html
| All times are GMT -8. The time now is 03:08 PM. |
