V-Tail
What are the difference between V-tail and Normal? Are the harder to fly? Does it matter or just personal preference, I have notice a lot of sailplanes have them.
Thanks |
RE: V-Tail
In theory, they have lower drag, hence their use in some sailplanes and some pylon racers. To use one, you will need a radio capable of V-tail or elevon mixing, although it is possible to build a plane that uses mechanical mixing.
They are no more difficult to fly than standard tails. |
RE: V-Tail
When flying you can't tell the difference.
RE: V-Tail
Most of the V tails react a little slower. I can roll a gentle lady glider with a regular tail, but I can't roll any of my V tail gliders. In full scale, the V tail Bonanza shimmies when it flies. The guy in the back seat gets it worse than the ones up front. I don't care for them very much personally, but some really like them.
RE: V-Tail
Yup, flying a full scale V-tail Bonanza is a bit interesting the first time you do it, especially if it's windy! That little side to side oscillation, although slight, takes a couple of flights to get used to. Once you get past that, they're great performers, especially if you're flying one that 's been injected and turbocharged!
RE: V-Tail
One advantage of V tails is that the tail is less likely to be damaged if you belly land the plane. A standard tail plane will drag the H stab in the grass, but a V tail reduces the stress on the tail when belly landing on grass.
RE: V-Tail
ORIGINAL: Lowlevlflyer Yup, flying a full scale V-tail Bonanza is a bit interesting the first time you do it, especially if it's windy! That little side to side oscillation, although slight, takes a couple of flights to get used to. Once you get past that, they're great performers, especially if you're flying one that 's been injected and turbocharged! |
| All times are GMT -8. The time now is 03:26 AM. |
