RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Different between 4 cycle prop an 2 cycle props?? (https://www.rcuniverse.com/forum/beginners-85/4058827-different-between-4-cycle-prop-2-cycle-props.html)
357magnum 03-20-2006 02:37 PM
Could someone please tell me the different between a 4 cycle prop and a 2 cycle prop. I have seen a Rev-up prop that said it was for 4 cycle. Thanks for any information.
bubbagates 03-20-2006 03:00 PM
RE: Different between 4 cycle prop an 2 cycle props??
There is no difference that I have ever come accross
bruce88123 03-20-2006 03:06 PM
Tower has some props they advertise as "four stroke" but they don't say what they really mean by that or the difference. I've never seen anyone use such a prop.
jaka 03-20-2006 03:10 PM
Hi!
There is no difference!!! All propellers could be used on any engine. Simple as that.
Some manufacturers/advertisers just try to sell things.;) Don't belive every thing you read...
Regards!
Jan K
Sweden
britbrat 03-20-2006 03:19 PM
The label
JohnW 03-20-2006 03:20 PM
The difference is that some props are designed to revolve twice per power cycle while others expect a power cycle every revolution. OK, that is complete BS. There really isn’t any such thing as a 4C vs 2C prop… it is just marketing. However, there may be prop designs that lend themselves more toward one engine type. 4C engine tend to produce their power at lower RPMs compared to 2C. This RPM/power curve difference does lean toward slightly different ideal designs for 4C vs 2C props. But even so, any prop with the proper loading will work on any engine, which is why in general you will never see a prop marked as for 4C or 2C as they work fine on either. Cheers.
357magnum 03-20-2006 03:21 PM
Thanks for the fast reply. I did't think there was a different Thanks again.
MannyEdge 03-20-2006 03:53 PM
ORIGINAL: britbrat
The label
LOL!!! That is great. :D
bruce88123 03-20-2006 04:28 PM
ORIGINAL: 357magnum
The correct word is: "DIFFERENCE".
mnrcaerobat 03-20-2006 05:32 PM
ORIGINAL: bruce88123
ORIGINAL: 357magnum
Hey Bruce, were you an English professor? Are you still? Or just a purrrr...fectionist?
bruce88123 03-20-2006 05:50 PM
ORIGINAL: mnrcaerobat
ORIGINAL: 357magnum
Just a person trying to help someone out.
ClarkFlyer 03-21-2006 11:19 AM
Interesting post. I bought a Master 12X4 to use on my OS 50SX and I noticed that it was VERY noisy in flight. I mentioned it to the guy at the LHS and he told me it was designed for a 4 stroke and although it would be noisy on a 2 stroke that it wouldn't hurt anything. He claimed that prop is designed for much lower RPMs. Hmmmm, what gives?
bruce88123 03-21-2006 11:35 AM
DUH! All props are quieter when turned slower.
Fastsky 03-21-2006 11:56 AM
That prop is probably turning high rpms on that engine. The suggested props for the 50SX are 10-8 to 11-7. To go to a 12" prop a 12-6 would be a match or you might be able to go to a 12-5. [8D]
bubbagates 03-21-2006 12:59 PM
Noisy props are caused by several things. Too much RPM, blade shape, tip shape and a small host of others though the 3 I mentioned are most common.
Master Airscrew props are amongts the loudest around followed by Zinger. Both flex allot so are also somewhat inefficent. For glow engines 18 inch and below I'd stick with APC. Tons quieter and much more efficent
bruce88123 03-21-2006 01:16 PM
ORIGINAL: bubbagates
Both flew allot so
Hope you meant "Flex". :D
bubbagates 03-21-2006 01:26 PM
It says flew...I do not know where you got that quote from ;)....I know it says I edited it but it wasn't me ;):D
Nah, I fixed it.
I think Bruce got a girlfriend that teaches english. He's been running around correcting spelling mistakes for everyone. ;)
bruce88123 03-21-2006 01:32 PM
Nah, my mother just wouldn't tolerate that type of thing when I grew up. Must be why I was runner-up in high school spelling bee. The winner was a girl, of course, but I barely knew her.
I try not to be too picky but sometimes it changes the entire message, so I critique for clarity. :D
bubbagates 03-21-2006 01:42 PM
No problem Bruse. I was just bustin' on ya
MinnFlyer 03-21-2006 03:36 PM
Both flex allot
In that case, I'm sure you meant "a lot"
Sorry, couldn't resist :D
bruce88123 03-21-2006 03:38 PM
ORIGINAL: MinnFlyer
Both flex allot
I was being nice as I figured everyone would understand that error. :D
bubbagates 03-21-2006 03:46 PM
My foot is tasting pretty bad right now :D[:'(]
bruce88123 03-21-2006 03:55 PM
We did take it easy on you yesterday and it WAS your day. :D
ptulmer 03-21-2006 04:53 PM
Actually, there is a difference between the props. A propeller designed for 4 cycle engines may have broader blades and a different design to make use of the greater torque available. Electric props are a more obvious example. Sure, they can be put on a 2 cycle, but it's not as efficient. Just like a 2c prop isn't as efficient on a 4c engine. Just because the load is the same, it doesn't mean it's delivering the same thrust. Heck, you can get different amounts of thrust from brand to brand with the same loading.
B.L.E. 03-21-2006 10:58 PM
The main reason you don't use electric props on glow engines is because they are not designed for the rpm and torque that a glow engine can put out, you risk injury from prop failure. Using glow engine props on a electric is safe but the overdesigned prop adds ounces of needless weight to the plane. The ultra high powered electric systems that rival glow power and rpm should use glow engine props for the same reason glow engines need them.
Today, 4-stroke engines are spinning 10,000+ rpm and higher in some cases. The power gap has really closed up so I don't think they need special props. Those 4-stroke Rev Ups may be relics of the days when 4-stroke engines had open rocker arms and only revved 8,000 rpm.
