Where do I get this screw and bolt?
1 Attachment(s)
Any help locating a place to get these would be appreciated.
And if someone could tell me what the one on the left is called, that would also be appreciated. |
RE: Where do I get this screw and bolt?
When I'm looking for screws and bolts I go to McMaster-Carr: http://www.mcmaster.com/
The one on the left looks like a broken or cut off DECK screw. The one on the right just looks like a standard bolt.
I don't know if you have access to a Home Depot or Lowe's but if you do they should have them both. If not try a local hardware, they look like they are probably pretty common items. ENJOY !!! RED |
second that ace hardware or home depot looks like a common screw to me
I tried a local hardware store, and they don't carry sizes this small. They suggested a hobby shop.
Piper Chuck, I looked briefly at that site but couldn't find the one on the right. Red Head, I'll look at deck screws, but the only one's I can find on the internet don't have thread going all the way to the head. Thanks so the help so far. |
[link=http://rtlfasteners.com/RC/m.html]nuts n bolts[/link]
don't know about the left one I'd substitute a drywall screw. these guy have any hobby nut bolt screw you'll need. the assortments are great |
Try sending the pic to these guys... Have bought all sorts of odd stuff from them...
http://rtlfasteners.com/RC/index.html Here's the link to their catalog https://rtlfasteners.com/Merchant2/S...atalog.pdf.pdf Cheers! Jim |
If you decide to get the screws from RTL, make sure you get some socket head servo screws. These things are the best thing since sliced bread.
Check here too:
http://www.microfasteners.com |
What do the screws fit? Sometimes knowing the application helps, sometimes it doesn't.
the one on the left looks like a plastic type screw Ive seen them in portable radios and a lot of plastic things,those free toys you get at the burger joints use those also it does look like the tip was cut off
Tips on both are con-cave and were formed that way. Typical use might be assemble of plastic parts.
Unless Timepilot gives us a useage it will be hard to help much more IMO. |
| All times are GMT -8. The time now is 08:41 PM. |
