RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   OS 70 Surpass carb (https://www.rcuniverse.com/forum/beginners-85/4304595-os-70-surpass-carb.html)
CB36 05-22-2006 10:46 AM
OS 70 Surpass carb
Hi;
Can the carb be reversed on the 70 Surpass? I've yet to buy it, but when I do I'll need the throttle arm on the other side. Obviously, I assume this will reverse the throttle direction.
It's going in a H9 Cub.
TimC 05-22-2006 10:53 AM
RE: OS 70 Surpass carb
I haven't reversed mine CB36, but a quick check of the manual found that this is possible.
RCKen 05-22-2006 10:54 AM
CB36,
The simple answer is yes, you can reverse it. It's a pretty easy procedure to switch it around.
Hope this helps
Ken
MinnFlyer 05-22-2006 05:42 PM
Yup, I do it all the time
