RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   AP .061 prop question HELP!! (https://www.rcuniverse.com/forum/beginners-85/4387571-ap-061-prop-question-help.html)
kilmerelrc 06-13-2006 08:49 PM
I just purchased a new AP .061 Wasp engine. The newer engines no longer have the prop bolt and such and now have a typical prop shaft with a spinner on the end. The manual calls for APC props to be used for break in and so on. I purchased the recomended APC prop but the props center hole is too large for the AP engine shaft. Is this due to AP switching to a spinner instead of the typical prop bolt? Has anyone else had a problem like this? Please let me know if there is a solution out there for me. Thanks. Chris
zurhahn 06-13-2006 09:09 PM
RE: AP .061 prop question HELP!!
I would just go with a Master Airscrew 6x3 1/2A prop. I have a norvel 061 and it runs very well with it.
zurhahn 06-13-2006 09:14 PM
APC props give more thrust at the upper range of the RPMs. Master Airscrew props give more thrust at the lower to mid range of RPMs.
Jim Thomerson 06-13-2006 10:42 PM
You can make a bushing out of a piece of tubing. This is necessary with the APC props on most 1/2A (more or less) size engines.
