RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Pattern vs. 3D (https://www.rcuniverse.com/forum/beginners-85/4406153-pattern-vs-3d.html)
mikexnxike01 06-19-2006 09:35 AM
Pattern vs. 3D
What is the difference between Pattern flying and 3D flying?
coolbean 06-19-2006 10:24 AM
RE: Pattern vs. 3D
Pattern is a very specific sequence of manuvers in a very specific airspace. The idea is to do everything smooth, at the right angle, and all at the same speed. All of the manuvers occure in the same verticle plane. Manuvers include, immalman, split-S Cuban 8, stall turn, all with or without rolls.
3D is flying beyond the normal flight envelope for an airframe by using excessive thrust and extreme control throws. Manuvers include, hovering, waterfall, torque roll, harriers, rolling harriers, wall.
bkdavy 06-19-2006 11:43 AM
RE: Pattern vs. 3D
Or more simply, 3D is flying an engine, pattern is flying a plane.:D
Brad
Mr67Stang 06-19-2006 11:50 AM
RE: Pattern vs. 3D
bkdavy
Status: online Or more simply, 3D is flying an engine, pattern is flying a plane.
Brad
Hey now... There is a time and place for both FLYING styles and I can apreciate both. But it takes both an engine and a plane to fly either style. I just like the looks on people faces when they say, "a plane can't do that!":D
MinnFlyer 06-19-2006 12:58 PM
RE: Pattern vs. 3D
Or "A plane SHOULD'NT do that" :D
tuwood 06-19-2006 01:02 PM
RE: Pattern vs. 3D
And both are hard to do and require a lot of practice!!
RCKen 06-19-2006 01:12 PM
RE: Pattern vs. 3D
ORIGINAL: MinnFlyer
3D flying is almost a contridiction in terms. It is defined as maneuvers performes while the wing is stalled out. Since the wing isn't producing any lift it's technically not flying. So yes, what was said above is true... 3D is flying an engine. Pattern is flying a wing, because the wing is producing the lift needed to stay in the air.
Ken
Mr67Stang 06-19-2006 03:11 PM
RE: Pattern vs. 3D
Ken
What is a prop but a rotating wing?
mstroh3961 06-19-2006 05:17 PM
RE: Pattern vs. 3D
ORIGINAL: Mr67Stang
Ken
Now you went and blew his theory out of the water!:D
Jim Thomerson 06-19-2006 06:39 PM
RE: Pattern vs. 3D
Are you saying that a 3-D airplane is just a poorly designed rotary wing aircraft (helicopter)?
(I'm a control line flier just having fun.):D
MikeEast 06-19-2006 07:19 PM
RE: Pattern vs. 3D
1 Attachment(s)
[link=http://What is pattern flying]http://www.rcuniverse.com/forum/m_3766720/tm.htm[/link]
Pattern and 3D are different but to do either well requires a tremendous amount of skill, practice and some natural ability. I fly both and find that they really compliment one another from a skills perspective. You learn about everything related to building, setup and control with both.. But if I had to single out one thing it would be how to fly with the rudder. Both force you to use the rudder constantly. There is seldom a moment when you are not on the rudder for one reason or another when doing pattern, 3D or IMAC. IMAC is the scale plane equal to pattern. The planes are larger and are scale replicas of an aerobatic plane. Pattern requires the plane will fit inside of a 2x2 meter box and weigh less than 5KG or roughly 11 pounds. The planes have evolved into sleek, powerful and graceful beauties.
Pattern is several things.
1st off its fun.
2nd, its about being graceful and precise and in control at all times.
You achieve grace and precision by honing your flying skills through TONS of practice and learning how to put your airplane exactly where you want it to be, and you control exactly how it gets there. Its about control. You learn how to make straight lines and symmetrical geometic figures and you put them exactly where you want them in space. If you work hard enough you will be able to make a square loop square, a round loop round, a 45 degree line right at 45 degrees. You learn about radius management, roll rates, and generally it will improve your skills 1000% even if you never go to a contest. Basically depending on what level you in, its a sequence of 10-20 maneuvers that consist of centered maneuvers that are flown relative to the center, right in front of the pilot. Before and after a centered maneuver you perform a turnaround maneuver at the end of the "box". Its sortof like flying in a 3 dimensional skateboard bowl.
3D is about fun[8D], control and adrenaline [>:] . If done correctly its about truly mastering control of an airplane so that you can do just about anything you want without crashing. There is flip flopping around,, and then there is 3D. To do 3D with grace and control is about as elegant as it gets, but it takes a ton of practice and you really have to know how to properly setup an airplane to make it do what you want it to do. As has been said most of the manuevers rely on a well setup plane, bigtime surface deflection, a somewhat aft CG and POWER. You spend most of the flight in a stalled condition and you need the engine to be there when you need power. The beautiful thing is, the better you get at 3D, the less you get into awkward positions that require tons of power to get you out of trouble. A really good 3D pilot can perform most of the maneuvers including hovering without a radically setup plane. But that person is also not making mistakes that require big power and big throws to correct or get out of trouble.
Here is a pic of a pattern and an IMAC/3D plane.
tuwood 06-19-2006 07:43 PM
RE: Pattern vs. 3D
ORIGINAL: MikeEast
1st off its fun.
Yeah, what he said :D
Nice explanation Mike!! I agree that they both compliment each other. I really took to 3D & have gotten decent at it, but I'm almost embarrassed to pull off a perfect rolling harrier & then struggle at flying a 4 point roll. [sm=confused.gif]
When I get my 30% Edge in the air I plan to start learning IMAC as well as 3D because I think they are both equally impressive & when combined can make for a very impressive flight. ;)
air mail rcu 06-19-2006 07:57 PM
RE: Pattern vs. 3D
The difference between pattern and 3D is that with 3D I can make money. A friend of mine was looking at my planes. I said that one will hover. He said planes can't hover. I said bet me. A fast trip to the park and he lost his bet. :D
Cyclic Hardover 06-19-2006 08:34 PM
RE: Pattern vs. 3D
My definition of 3d involves a pilot flying anyway he can to just royaly p--s you off. The manuever of choice seems to be hanging from a prop right in front of another pilots face and dead center over the runway.
MikeEast 06-19-2006 10:55 PM
RE: Pattern vs. 3D
ORIGINAL: Cyclic Hardover
If that is your experience it is not the normal. I'm sorry that is your experience, that stinks.
mstroh3961 06-19-2006 11:16 PM
RE: Pattern vs. 3D
Putting pattern skills and 3D together is one of the most visualy stunning things to watch. look for some mark leesburg JR vidios.... He is amazing!:D
MikeEast 06-19-2006 11:43 PM
RE: Pattern vs. 3D
In my opinion Mark Leseburg is the greatest pilot to ever pickup a transmitter. He has superhuman skills. Whats cool is that he is not only great at RC flying but at just over 20 years old he is an accomplished scale aerobatic pilot and from what I have read is one heck of a golf player.
mstroh3961 06-20-2006 12:33 AM
RE: Pattern vs. 3D
And a super nice guy to set and talk to in the evenings at an event. Hes coming to my clubs big bird event again this year as a fetured pilot.
[link=http://www.loveairrc.org/Events/bigbird/Big%20Bird%20'06.htm]13th Anual Rocky Mountian Big Bird Festival[/link]
You are all invited to join us for the fun!
