RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   side thrust (https://www.rcuniverse.com/forum/beginners-85/4409912-side-thrust.html)
skyraider2 06-20-2006 09:42 AM
side thrust
How do i adjust the side thrust on my plane, When i pull the plane into a vertical climb, it veers to the right [:o]
raideron 06-20-2006 10:10 AM
RE: side thrust
If your plane is "trimmed" out good!.. min./no wind on your test, run a few tests to be sure...
You may have to much Rt. thrust??? the normal thrust that's needed and usuaully built into
the firewall..
If so you can add a washer/s to the top and botton mounting bolts on the side that you need it
on, on the engine mount between the mount and firewall.. You can also buy thrust plates...
But the washers work just as good :D If you do add washers or plates... Make sure your
bolts are long enough to go completely through the blindnuts....... Ohh & loc-tite in.. :D
ghtracey 06-20-2006 11:22 AM
RE: side thrust
Here's a reference site for you that may help some. [link=http://www.probuild-uk.co.uk/factsheets/trimchart.php]Fact Sheet: Trimming Chart[/link]
Cheers,
Graham
bruce88123 06-20-2006 11:43 AM
RE: side thrust
Also recheck your lateral balance. A heavy wing could cause some of this too.
raideron 06-20-2006 12:26 PM
RE: side thrust
Hey Bruce... Great info... Thanks for the link to it :D
