RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   center of gravity..How Close?? (https://www.rcuniverse.com/forum/beginners-85/4421065-center-gravity-how-close.html)
Sniper_Brad 06-23-2006 12:45 AM
Hello. I am building a hanger 9 showtime 4d and my CG is approx. 1 inch too far to the rear. As per the instruction manual. Is this close enough or should I add lead weight to the front? I would like to keep it as light as posible. Moving my battery pack is not an option as they have a recess for it already. Any advice on CG would [8D]be greatly appreciated. Thank you in advance for the help.
alan0899 06-23-2006 02:00 AM
RE: center of gravity..How Close??
G'day Mate,
1" is a long way out, 1/4" changes can be detected when flying, make sure you are on the recomended CG point or even a tad forward, fly it & then adjust as required.
Dr1Driver 06-23-2006 05:57 AM
Add the weight!!!
Nose heavy planes may fly poorly. Tail heavy planes may fly ONCE!
Dr.1
MinnFlyer 06-23-2006 09:19 AM
1 Attachment(s)
I don't care if there's a gold placard showing where the battery goes, move it forward. Strap it to the side of the Engine Box and drill a hole through the firewall for the wire if you need to.
Then, if it still needs it, add lead.
As was said before, you can get away with being a little nose-heavy, but you do NOT want to fly a plane that is Tail-Heavy.
RCKen 06-23-2006 09:37 AM
ORIGINAL: MinnFlyer
A very nose heavy plane flies poorly..... A very tail heavy plane flies only once!! :D
Ken
MikeEast 06-23-2006 10:47 AM
Minn beat me to it... Find a place to move that battery pack forward. Make a spot for it if you can. Usually a couple of small holes drilled to accept zip ties will work very well.
Then add weight if that does not work.. I would not add weight unless you have no other choice as the plane will not fly as well with added weight.
However, in case you havent already heard it before;) Nose heavy planes fly like crap, tail heavy planes only fly once.
Deadeye 06-23-2006 11:32 AM
If you do have to add weight, consider a heavy prop hub that fits under the spinner. The farther forward you add weight, the less you have to add. And since nobody has mentioned it a nose heavy plane flys poorly, but a tail heavy plane flys once. :D
Sniper_Brad 06-23-2006 11:36 AM
Awesome advice gentlemen, thank you. Looks like I'm drilling some holes to move the battery pack...
Dr1Driver 06-23-2006 10:49 PM
Mike East
RCKen
Dr1Driver
Perhaps you missed their posts? :D
However, it DOES bear repeating.
Dr.1
StevL 07-31-2006 11:29 AM
Using a flat pack we were able to position the batteries under the fuel tank and added a small piece of balsa to keep them from sliding aft (just in case).
We ended up having the cg 1/8" toward the tail.
doubledee 08-01-2006 09:27 AM
I had a nose heavy airplane once, it really flew poorly. I moved the CG aft so it was tail heavy and it only flew once. :D
regards,
doubledee
