RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   I need help from someone with an SU26 (https://www.rcuniverse.com/forum/beginners-85/4448932-i-need-help-someone-su26.html)
coolbean 06-30-2006 12:17 PM
I need pictures and measurements please.
Mostly I need a picture of the bottom as I can't seem to find any.
I need measurements (I dont' care what size you have, I'll scale it to my needs)
wing:
wingspan
root chord
tip chord
root thickness
tip thickness
fuse:
Width of fuse at nose (not the inner part, but the widest part)
Nose to LE of wing
Nose to tail (tale of fuse, not rudder)
Nose to front of canopy
Top of wing to top of fuse
Bottom of fuse to top of fuse right beheind the canopy
tailfeathers:
width of horiz stab and elevator
height of vert stab and rudder
I know that is a lot of measurements and I would really appreciate anything anyone can give me.
a65l 06-30-2006 05:40 PM
RE: I need help from someone with an SU26
You might have better luck asking for a set of plans. That way you could get your measurements exactally as the designer intended, and there's no doubt that you have exactally teh measurement you need. Plus you can go back later if you forgot something.
Andy
coolbean 06-30-2006 07:05 PM
1 Attachment(s)
Plans would be great too! I found this side view from the 40% aerotech Su26mx that is in development. I PMed them asking if they had a top view available.
