RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   RCM 40 Tank (https://www.rcuniverse.com/forum/beginners-85/4495436-rcm-40-tank.html)
suicidemachine 07-12-2006 10:48 PM
RCM 40 Tank
I'm building my RCM 40 trainer. Smooth as silk building till the tank no biggie, the stopper pops in the tank good but it has a little groove in the middle of the stopper that sits in the tank opening. I can rotate the stopper with little force and isn't snug. Is this the way it is, will it expand when filled with fuel or do I have a problem?
agexpert 07-12-2006 10:58 PM
RE: RCM 40 Tank
pressure-test it with air under water and see if it leaks. If so; tighten the screw, add sealant, or buy another tank for like $7.
suicidemachine 07-12-2006 11:21 PM
RE: RCM 40 Tank
Does the screw compress the stopper to in a sense squash it and give it a wider diameter?
alan0899 07-13-2006 02:28 AM
RE: RCM 40 Tank
G'day Mate,
Yes it should be firm, so no fuel gets out & no air gets in, other than through the tubes.
suicidemachine 07-13-2006 02:41 AM
RE: RCM 40 Tank
I tightened up the screw and all is good. Thnx guys :D
